I just purchased a 99 legacy outback. I went to fill up the gas tank and when doing so I noticed gas on the ground. When I got home I flipped the back seat and there was a puddle of gas other the driver side same side it was leaking underneath.
Has anyone one else had this problem and if so what is the first step.
Thanks
Probably the tank is rusted out. Those are so jammed up in there its hard to see anything to figure out where exactly it rusted out, but that's the only reason I can think of that you would see gas dumping out on the drivers side.
I'm not aware of a source for a new tank other than a dealer which will be $$$.
Your best option is to find a used tank with less rust. Try searching Car-part.com for parts yards near you.
You could try a local pick-n-pull type yard where you can pull it yourself. Problem with most of those is they punch a hole in the tank to drain it when the car comes in.
