stoogesman Posted December 10, 2014 Share Posted December 10, 2014 Hi everyone, My '85 DL is in need of some fresh rear wheel bearings. I am a little bit confused on what I see on Napa/RockAuto as to what part(s) I need. I see there is an inner and outer bearing. Napa shows the inner and the outer which are below: Inner: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Inner-Rear-Wheel/_/R-BRGBR30206_0141319794 Outer: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Outer-Rear-Wheel/_/R-BRGBR30204_0141319795 Then Napa also lists this bearing... Is this both inner and outer combined?? http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Rear-Wheel/_/R-ATM2123001_0418666376 I also read that I should buy both inner and outer replacement seals. From what I see, they don't come with the Napa bearings. Any idea where I can get those and what the part # would be? Thanks! Craig Link to comment Share on other sites More sharing options...
stratman977 Posted December 10, 2014 Share Posted December 10, 2014 http://parts.subaru.com/a/Subaru_1985_DLGLGL10RSRXDL-WAGON/_54106_6024626/FRONT-AXLE/A10-280-A1.html Link to comment Share on other sites More sharing options...
stoogesman Posted December 10, 2014 Author Share Posted December 10, 2014 On 12/10/2014 at 8:40 PM, stratman977 said: http://parts.subaru.com/a/Subaru_1985_DLGLGL10RSRXDL-WAGON/_54106_6024626/FRONT-AXLE/A10-280-A1.html Thanks. That is for the front. I am trying to click to access the rear axle set up but the site won't let me...It keeps showing front components. Link to comment Share on other sites More sharing options...
mikaleda Posted December 10, 2014 Share Posted December 10, 2014 (edited) On 12/10/2014 at 8:29 PM, stoogesman said: Hi everyone, My '85 DL is in need of some fresh rear wheel bearings. I am a little bit confused on what I see on Napa/RockAuto as to what part(s) I need. I see there is an inner and outer bearing. Napa shows the inner and the outer which are below: Inner: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Inner-Rear-Wheel/_/R-BRGBR30206_0141319794 Outer: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Outer-Rear-Wheel/_/R-BRGBR30204_0141319795 Then Napa also lists this bearing... Is this both inner and outer combined?? http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Rear-Wheel/_/R-ATM2123001_0418666376 I also read that I should buy both inner and outer replacement seals. From what I see, they don't come with the Napa bearings. Any idea where I can get those and what the part # would be? Thanks! Craig Yes these are the rear wheel bearings. The first option is like the original two peice style and the latter is the newer style one piece race. Both styles will work just fine Yes always replace seals, Napa should have the part number Edited December 10, 2014 by mikaleda Link to comment Share on other sites More sharing options...
stoogesman Posted December 10, 2014 Author Share Posted December 10, 2014 On 12/10/2014 at 9:36 PM, mikaleda said: Yes these are the rear wheel bearings. The first option is like the original two peice style and the latter is the newer style one piece race. Both styles will work just fine Yes always replace seals, Napa should have the part number Ok, great! Thank you! I am on NAPA's website and I don't see them showing the seals at all? Link to comment Share on other sites More sharing options...
mikaleda Posted December 10, 2014 Share Posted December 10, 2014 On 12/10/2014 at 9:46 PM, stoogesman said: Ok, great! Thank you! I am on NAPA's website and I don't see them showing the seals at all? Give them a call their more than likely going to need to look it up in the book Link to comment Share on other sites More sharing options...
stoogesman Posted December 10, 2014 Author Share Posted December 10, 2014 On 12/10/2014 at 9:49 PM, mikaleda said: Give them a call their more than likely going to need to look it up in the book That I will do. The I just moved so I am HOPING this Napa has a little bit more enthusiasm than the last. The last Napa I dealt with would look in there crappy computers and say, "nah, we don't got it". In most cases I would have to search for part #'s. Thanks legacy specialist for the info. I'll be huffing and puffing to do the rear bearings this weekend. Wish us luck! Link to comment Share on other sites More sharing options...
stoogesman Posted December 10, 2014 Author Share Posted December 10, 2014 (edited) See below. Combining. Edited December 10, 2014 by stoogesman Link to comment Share on other sites More sharing options...
stoogesman Posted December 10, 2014 Author Share Posted December 10, 2014 (edited) On 12/10/2014 at 9:36 PM, mikaleda said: Yes these are the rear wheel bearings. The first option is like the original two peice style and the latter is the newer style one piece race. Both styles will work just fine Yes always replace seals, Napa should have the part number In your opinion, would you say that the upgraded rear bearing shown in the link above make for an easier install? Also, I am still a tad bit confused. So this bearing in the link below: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Rear-Wheel/_/R-ATM2123001_0418666376 This bearing is the inner? I will still need to purchase the outer? I am on Rockauto.com and only see the new style inner bearings. The outer rear bearings for sale are all for front wheel drive Subi's.... Edited December 10, 2014 by stoogesman Link to comment Share on other sites More sharing options...
mikaleda Posted December 11, 2014 Share Posted December 11, 2014 On 12/10/2014 at 11:33 PM, stoogesman said: In your opinion, would you say that the upgraded rear bearing shown in the link above make for an easier install? Also, I am still a tad bit confused. So this bearing in the link below: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Rear-Wheel/_/R-ATM2123001_0418666376 This bearing is the inner? I will still need to purchase the outer? I am on Rockauto.com and only see the new style inner bearings. The outer rear bearings for sale are all for front wheel drive Subi's.... That style is the inner and outer it just has one solid race. It is the easier option for installation Link to comment Share on other sites More sharing options...
stoogesman Posted December 11, 2014 Author Share Posted December 11, 2014 On 12/11/2014 at 1:00 AM, mikaleda said: That style is the inner and outer it just has one solid race. It is the easier option for installation Thank you so much! My local advance auto has them in stock. Link to comment Share on other sites More sharing options...
stratman977 Posted December 11, 2014 Share Posted December 11, 2014 You have to punch your car back into the system to navigate on there after you click on the link. It's comes in handy even if you don't buy from subaru. Heres the rear. http://parts.subaru.com/showAssembly.aspx?makeName=subaru&modelYear=1985&modelName=dlglgl10rsrxdl-wagon&ukey_assembly=6028557&ukey_category=54106&assembly=a10-281-b1 Link to comment Share on other sites More sharing options...
stoogesman Posted December 11, 2014 Author Share Posted December 11, 2014 On 12/11/2014 at 1:24 PM, stratman977 said: You have to punch your car back into the system to navigate on there after you click on the link. It's comes in handy even if you don't buy from subaru. Heres the rear. http://parts.subaru.com/showAssembly.aspx?makeName=subaru&modelYear=1985&modelName=dlglgl10rsrxdl-wagon&ukey_assembly=6028557&ukey_category=54106&assembly=a10-281-b1 Thanks stratman977. Where is Belle Vernon, PA? I am in Bloomsburg... Link to comment Share on other sites More sharing options...
stratman977 Posted December 11, 2014 Share Posted December 11, 2014 I'm an hour south of Pittsburgh, a long ways from you unfortunately. Link to comment Share on other sites More sharing options...
TomRhere Posted December 11, 2014 Share Posted December 11, 2014 Wheel seals for the rear of the EA82 4WD are, National Seals numbers; Inner 224015 Outer 225005 1 Link to comment Share on other sites More sharing options...
stoogesman Posted December 12, 2014 Author Share Posted December 12, 2014 On 12/11/2014 at 4:08 PM, stratman977 said: I'm an hour south of Pittsburgh, a long ways from you unfortunately. That is quite far. My sister lives in Marysville. Link to comment Share on other sites More sharing options...
stoogesman Posted December 12, 2014 Author Share Posted December 12, 2014 On 12/11/2014 at 11:05 PM, TomRhere said: Wheel seals for the rear of the EA82 4WD are, National Seals numbers; Inner 224015 Outer 225005 Thank you TomRhere! Link to comment Share on other sites More sharing options...
