DCCommuter Posted December 12, 2014 Share Posted December 12, 2014 Hi all, I'm wondering what's going on with my CVT in my 2014 XV. This happens only occasionally and in similar situations. In manual mode, and 2nd gear, hitting the + paddle sometimes does not initiate an upshift. This is with both the upshift and downshift arrows visible in the display, and generally above 3,000 RPM and below 5,000 RPM. So the car remains in second gear and revs increase. When I hit the paddle again, it upshifts. It tends to happen after cruising slowly in 2nd gear for a couple hundred feet in traffic, then accelerating. Any thoughts from you guys? Thanks! Robert Link to comment Share on other sites More sharing options...
nipper Posted December 16, 2014 Share Posted December 16, 2014 Hard to tell if it is a electrical issue from the paddles or a mechanical system issue. If you leave it in drive does it behave itself? Link to comment Share on other sites More sharing options...
ezapar Posted December 17, 2014 Share Posted December 17, 2014 Why are you gooding around with your paddles? I only use them to keep the car in a gear to slow it down long hills. Link to comment Share on other sites More sharing options...
nipper Posted December 17, 2014 Share Posted December 17, 2014 I would suspect "I just paid 24,000 for these freaking paddles and by gum i am going to use them." 1 Link to comment Share on other sites More sharing options...
DCCommuter Posted December 18, 2014 Author Share Posted December 18, 2014 The paddles are meant to be used, and they're fun to use. I've since learned that this missed upshift occurs only just as the downshift arrow is disappearing. Link to comment Share on other sites More sharing options...
unibrook Posted April 4, 2016 Share Posted April 4, 2016 (edited) Do the paddles help lock in a ratio that will help avoid that "high rev/no speed increase/CVT rubber band effect" when trying to accelerate at around 40mph to merge onto highway? Edited April 4, 2016 by unibrook Link to comment Share on other sites More sharing options...
Leeroy Posted April 5, 2016 Share Posted April 5, 2016 Are you sure it is not just the computer overriding the paddles? Is the behaviour new or has it always happened? As I am sure you would be aware CVTs don't actually have any gears as such. Any 'steps' you feel are just engineered to make the driving experience more familiar and natural feeling. Sorry I don't have any solutions but I am curious! Link to comment Share on other sites More sharing options...
