gicos Posted December 13, 2014 Share Posted December 13, 2014 Hello all. I'm hoping to gain a bit of knowledge. I've got a 98 Outback Wagon in desperate need of struts/springs. It's bottoming out on big bumps. I'd like to put stiffer springs in, both for towing a small trailer and to fit a bit bigger tire. I've read up on King, Baja, and Forester spring swaps. I'd like to go the Baja spring route, if they'll work. I've read the thread on Baja springs on a 2000 OBW, but can't find a cross refernce as to differences between 98 and 00 struts. Can anyone tell me if they're any different and if so what I'd need to make this work on a 98? Thanks much, Jason Link to comment Share on other sites More sharing options...
86BRATMAN Posted December 13, 2014 Share Posted December 13, 2014 You won't be able to use Baja struts or springs on your 98, well the fronts will work but the rear is completely different. If you go the forester route, use 03-08, the 98-02 springs are softer than the outback, and the rear struts are shorter. Link to comment Share on other sites More sharing options...
gicos Posted December 13, 2014 Author Share Posted December 13, 2014 Thanks Bratman. What I got from this thread: http://www.subaruoutback.org/forums/81-wheels-tires-brakes-suspension/22317-baja-springs-2000-outback-wagon-2.html is that the following were used to do the swap on a 2000: KYB GR2 dampers front and rearGas Strut 334275 FRONT RIGHTGas Strut 334276 FRONT LEFTGas Shock 341276 REARSOne set of front and rear 04-05 Baja springsYour existing Outback tophats, spring seats, and "stuff". What I'm gathering is that the 2000-2002 struts are different than the 98, but I'm not entirely clear how they differ of whether this can be made to work. The strut numbers above come up as fitting a 2000-2002 Outback. Link to comment Share on other sites More sharing options...
86BRATMAN Posted December 13, 2014 Share Posted December 13, 2014 It cannot be made to work, the only oem struts and springs that will lift your 98 are from the 03-08 forester. They retained the same suspension type through those years. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 13, 2014 Share Posted December 13, 2014 They completely changed the rear struts and springs in 2000, they're in no way compatible with each other. A 2000 rear strut http://www.subaruoutback.org/gallery//500/10308shockchange3.jpg Vs a 98 rear strut http://www.sspparts.com/e2/items/9110/IMG_8659.JPG 1 Link to comment Share on other sites More sharing options...
gicos Posted December 14, 2014 Author Share Posted December 14, 2014 Thank you so much gentlemen. That was exactly the information I was hoping for and you saved me a lot of anguish. I believe the Baja springs would have lasted longer than the Forester, but I'll put a fresh set of Forester springs on and see what I get. There's always King springs if they wear too fast. May the great Subaru gods bless all you do. Link to comment Share on other sites More sharing options...
