93 legacy l / STI swap?
qmc1134
Welcome to the USMB.
You would be better off trying to get a turbo legacy and swapping that into your Legacy.  The first gen legacy (90-94) has an OBD1 ECU and the newer STi's have OBD2, which require a bit more sensors, more wiring, etc.
I'm sure it can be done with a lot of time, money, and patience, but it's not a swap I would recommend trying.  Trying to find something of the similar year range to swap in would be my recommendation.  Either look for a first gen Legacy or an overseas EJ20G motor
You would need an entire 4wd rear suspension in addition to what you mentioned.
I don't think the OBD I/OBD II is a problem.  You'd just strip the entire engine wiring harness out of the WRX/STI and install it piggyback to the legacy harness.
Just like is done in an EA/EJ swap.
difficult but very doable.
