G'paX8 Posted December 14, 2014 Share Posted December 14, 2014 I recently became the owner of my 3rd Subaru. It is a 97 Legacy Outback and I love it (as I have my previous Subarus). This one seems to have a significant pull to the left. I can see than I need to put new CV boots on, but there is no play when I jack it up and attempt to rock or tip the wheel. Where should I look next? Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 15, 2014 Share Posted December 15, 2014 (edited) Probably needs an Alignment. If you have any play in the tie rod ends or ball joints replace those before having an alignment done. Make sure all 4 tires are properly inflated. If it's all solid, take it and get a 4 wheel alignment done. Edited December 15, 2014 by Fairtax4me Link to comment Share on other sites More sharing options...
johnceggleston Posted December 15, 2014 Share Posted December 15, 2014 pull to the left when driving straight? when braking? front end alignment would be my starting point. even before replacement axles. Link to comment Share on other sites More sharing options...
G'paX8 Posted December 15, 2014 Author Share Posted December 15, 2014 It pulls to the left when driving straight. Applying the brakes doesn't make it any worse........ I will check the ball joints and then go for the alignment. Thanks Link to comment Share on other sites More sharing options...
