Is my Ej22 running lean? W/ pics
Doing some maintenance on my 97 Imp OBS and had the headers off. Noticed the exhaust valves looked pretty white,l dont think they should look like this.Here are some pics.post-50789-0-73935800-1418704044_thumb.jpgpost-50789-0-70855200-1418704075_thumb.jpgpost-50789-0-55796000-1418704095_thumb.jpgpost-50789-0-89356300-1418704107_thumb.jpgpost-50789-0-09872900-1418704123_thumb.jpg Am I running lean?
Then there is this. Im not sure of the technical term but, it is where the passenger side A-arm connects to the frame. It looks loose. Not like the drivers side. Should I be concerned about this, or is it normal? If not how do I fix? Just tighten it up? Thanks!!post-50789-0-34230400-1418704390_thumb.jpgpost-50789-0-00918300-1418704411_thumb.jpg
Edited by Aluxes
Normal and normal.
That bushing should not be toght against the control arm. There is a certain amount of clearance that's supposed to be there to allow free rotation of the control arm and prevent the control arm from hitting the metal frame of the bushing. If the bushing is pressed tight against the control arm the control arm could be bent.
Normal and normal.
That bushing should not be tight against the control arm. There is a certain amount of clearance that's supposed to be there to allow free rotation of the control arm and prevent the control arm from hitting the metal frame of the bushing. If the bushing is pressed tight against the control arm the control arm could be bent.
  • Like 1
