I have a VLSD rear diff from a early 90's Legacy ss (4.1 ratio, w/stub shafts) and would like to install into my 98 impreza. My Impreza has the male axle shafts on diff side. Can I swap to legacy axles or build a hybrid axle w/ lego inside cv joints attached to the impreza axles? Any help would be great     Thanks, Pat
  • 3 weeks later...
Well..... I went to do my rear diff swap, purchased the correct axles, double checked gear ratios and put the car up. Once the car was in the air I noticed my Impreza L has got the VA style rear diff : ( (like the brighton), can I swap the T-style diff in anyways? I researched it and it was saying something about it binding or being incorrect. And since I'm here- foolish of me but, are the input flanges the same on both diffs? I should have checked when it was up in the air.... Duh!
