AKghandi Posted December 19, 2014 Share Posted December 19, 2014 (edited) So I was just thinking, anyone ever done a 6x6 wagon? My thought was take a wagon, cut it off right after the rear diff, take another wagon cut it right before the rear subframe. then weld the rear section onto the other wagon. might have to put a few peices of sheet metal to smooth it out and make rear side windows out of diamond plate unless you wanted to have custom rear side windows made. as for the 6x6 part, take the middle rear diff and another spare diff and mill the gear casing off to where it was just a pinion and case and then mill the cover on the other diff and weld the ouput pinion to the cover to make a diff with a pass through and then the rear most diff flipped upside down to spin it the right way.. fuel system would be easy, just slightly longer fuel hoses from the rear section brakes wouldn't be an issue, the rear most wheel don't really need brakes, but a couple simple adjustable proportioning valves would let you make some lines to the rear most wheels. only thing I think that might be an issue would be binding between the two rear diffs in sharp turns. just rambling basically but some time in the future when I have a good welder I'll get a couple cheap wagons and give it a shot. just a rough, VERY ROUGH idea. stole the pic from suberdave lol just imagine it lifted 4" or so Just thought I'd put the idea in someones head and see where it goes. Edited December 19, 2014 by AKghandi 2 Link to comment Share on other sites More sharing options...
two85s Posted December 19, 2014 Share Posted December 19, 2014 Sweeeeeet! Merry Christmas Akghandi! All the best to you and your family, Aaron Link to comment Share on other sites More sharing options...
AKghandi Posted December 19, 2014 Author Share Posted December 19, 2014 merry christmas to you too! Link to comment Share on other sites More sharing options...
jono Posted December 19, 2014 Share Posted December 19, 2014 no-o-o don't ditch the second fuel tank either - go dual tanks for longer touring range ! 2 Link to comment Share on other sites More sharing options...
AKghandi Posted December 19, 2014 Author Share Posted December 19, 2014 On 12/19/2014 at 8:55 AM, jono said: no-o-o don't ditch the second fuel tank either - go dual tanks for longer touring range ! thats actually a really good idea.. a fuel tank switching valve from an old ford or chevy would be easy to come by Link to comment Share on other sites More sharing options...
el_freddo Posted December 19, 2014 Share Posted December 19, 2014 I've had this thought before - but that's about as far as it got.A Datsun 720 transfer case with the low range blanked out with a set of short nose nissan/datsun diffs in the rear there would make it all work in my imagination - you'd need a 3 or 4 inch lift minimum!I'm sure someone can do a better photoshop of the concept with larger wheels as well!CheersBennie Link to comment Share on other sites More sharing options...
l75eya Posted December 19, 2014 Share Posted December 19, 2014 HAHAHA that's awesome! Do it!! Link to comment Share on other sites More sharing options...
Hsoj Posted December 19, 2014 Share Posted December 19, 2014 If you can mill the rear diff for an output pinion, I want one! I've been dying to make Suboataru! Link to comment Share on other sites More sharing options...
mikaleda Posted December 19, 2014 Share Posted December 19, 2014 That would be awsome! I'd say its totally worth a shot Link to comment Share on other sites More sharing options...
ferp420 Posted December 19, 2014 Share Posted December 19, 2014 i think it would be sick stock length maybe add some tracks for the snow Link to comment Share on other sites More sharing options...
AKghandi Posted December 20, 2014 Author Share Posted December 20, 2014 I really want to, but its cold and next summer i have 2 engine swaps on my plate, but summer after that i probably will. it would be the best adventure type vehicle i could imagine 1 Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted December 20, 2014 Share Posted December 20, 2014 I'm kinda surprised SJR has not tried this.... he has cut up wagons before and shortened them and stuff... this is just going in the other direction. Link to comment Share on other sites More sharing options...
AKghandi Posted December 20, 2014 Author Share Posted December 20, 2014 right? thats one of the reasons I posted this, I'd like to see someone with more resources than me give it a shot Link to comment Share on other sites More sharing options...
-tombba- Posted December 20, 2014 Share Posted December 20, 2014 You know it would look funny to add coupes rear section to a wagons back 2 Link to comment Share on other sites More sharing options...
