TPaul Posted December 23, 2014 Share Posted December 23, 2014 My 1992 Subaru loyale will start but not continue to run as soon as the ignition is in the run position. Has gas, new battery. No problem codes on ECU. Where should I look next? Link to comment Share on other sites More sharing options...
DaveT Posted December 23, 2014 Share Posted December 23, 2014 Will it run if you hold the gas pedal down a little? Link to comment Share on other sites More sharing options...
naru Posted December 23, 2014 Share Posted December 23, 2014 Start by making sure the coil remains powered up in the run position. Link to comment Share on other sites More sharing options...
TPaul Posted December 23, 2014 Author Share Posted December 23, 2014 Car will not run with the gas pedal down and we do have power to the coil when ignition is in the run position. Seems like its getting gas to start and then in run position shuts down. Thanks Paul Link to comment Share on other sites More sharing options...
Dee2 Posted December 24, 2014 Share Posted December 24, 2014 Maybe a faulty ignition switch, but It would help to know some background info. -- Is this a new problem ? -- Was anything done to the car recently ? -- What happens when the car dies, does it just quit or does it do a hurt dance ? 1 Link to comment Share on other sites More sharing options...
DaveT Posted December 24, 2014 Share Posted December 24, 2014 What I would check: tee in a fuel pressure gauge. Measure voltage at fuel pump while trying to start and run. Rig a temporary way to power the fuel pump - run wires from the pump connect or to the battery. Link to comment Share on other sites More sharing options...
TPaul Posted December 24, 2014 Author Share Posted December 24, 2014 THis is a new problem for sure. Only battery replacement recently. About 3 months ago, timing belts replaced due to seized damper (tensioner). Car dies as soon as the ignition is moved from start to run position. No sputtering. When problem first started, it seemed to lack power on acceleration on low RPMs and we attributed that to the dead battery? Will test voltage at the fuel pump in run position. Pump works fine in the start position with the clutch released, but will check in run. I've assumed that the ignition switch is OK because we have everything else working in run including power to the coil. Thanks for your suggestions. Link to comment Share on other sites More sharing options...
naru Posted December 24, 2014 Share Posted December 24, 2014 It might still be the switch. The coil does not draw any current with the engine stopped so a simple voltage check might not show a bad switch. I would eliminate the run contacts by running a temporary jumper wire (fused) between coil + and battery +. If it runs now,you will need to remove the wire to kill the motor. Link to comment Share on other sites More sharing options...
TPaul Posted December 24, 2014 Author Share Posted December 24, 2014 Won't run with coil+ to batt+. Link to comment Share on other sites More sharing options...
Gloyale Posted December 24, 2014 Share Posted December 24, 2014 Pull the ignition relay out from above the ECU. Install jumpers between the main contacts (2 sets) If it runs then, the problem is the ignintion switch. Link to comment Share on other sites More sharing options...
TPaul Posted December 27, 2014 Author Share Posted December 27, 2014 Thanks for your input all of you. Problem has been solved and I learned a bit about the loyale that I didn't know before. 1) With the green test connectors connected and the ignition on, the fuel pump recycles. No need to install jumpers or pull ignition relay to prove ignition is OK.. 2) If the Mass Flow Sensor is disconnected at the Sensor and the sensor is faulty, the car will still run. Reconnect and car will stall. So the problem was this sensor which had a lot of oil in the filter and the intake and unfortunately the car was smoking like crazy. Pulled plugs. Compression check - # 3 cylinder no compression. Conclusion: Rings no 3 cylinder gone resulting in blow back contaminating the mass flow sensor shutting the car down in run but would still start momentarily. So I will be doing a block swap with another engine I have in the next couple weeks and we should be good to go for another round! Thanks again for your input. 1 Link to comment Share on other sites More sharing options...
MR_Loyale Posted December 28, 2014 Share Posted December 28, 2014 That's odd. If I disconnect the mass airflow sensor on my Loyale, the car immediately dies. 1 Link to comment Share on other sites More sharing options...
TPaul Posted December 29, 2014 Author Share Posted December 29, 2014 Interesting,MR_Loyale. Both of mine work this way. If I take off the intake, they die but not if I take off the connector on the back of the Sensor. THanks. I won't rely on it but it worked for me this time. Link to comment Share on other sites More sharing options...
