To Pull Head or not to Pull Head.
So far what I have gathered regarding this is.
Tap size is 11mmx1.25
    Helicoil kits are rare for this size...
I had read something that the tap for
the head bolts is actually longer than the bolt
and that it may be possible to get a longer bolt
, chase the thread again and use a longer bolt
perhaps, an extra washer to adjust bolt length
in the taping.....
     Looking for some insight and suggestions...
Probably good to say again.... that
the vehicle did run hot on several
ocassions.... It did not run into the
read....... It has been cold enough
here to avoid that with running the
heater... Still it did get up in temp...
Which I believe is the cause of
my problem........ The temp issue
has been remedied..... with a
new thermostatic switch
Didn't see the posts ran onto page two...
Sorry, DaveT I missed your  post...
till after I added again... Yeah, I will look
online.
      DaveT Did you put the Helicoil in
while the engine was still in car?
Wondering...... Thanks, Micky
I'd be skeptical of a Helicoil here.  Some of the head bolts are very close to water and oil passeges.  Not much extra meat around them..I know on an EJ some of the holes a Helicoil would not work.
7/16ths fine thread is so close to m11 that it can be used.  1 thread difference over a 2 1/2" run.
I've replaced EJ head bolts with 7/16th fine thread B9 rod (high grade all thread) as head studs.
Drive the rod in tight to the bottom.....it won't ever come out.  This allows you to catch teh extra threads at the bottom.....although if the hole is badly stripped it may not be enough to hold.
I'm running an EJ22 in my wheeler like this right now.
So  take a piece of  7/16 B9 fine threaded rod and thread that in....
To Avoid the larger diameter hole of a Helicoil....
AND     Don't chase the threads (of original thread) Just thread rod in........
   I like this idea...,,,, any idea how much extra thread sits at the bottom?
So I called the local fastener place...
They well stock in bolts and the like.....
 I am looking for 7/16 fine thread B9  threaded rod....
If I could be pointed in the right direction, anyone
know where to get this? or what kind of places
would have such a thing......
Thanks, Micky
So here is a picture of the head.
All frankensteined up.........
Showing it's (threaded rod) poppin'
Initially, It was only one striped taping in the block
at Bolt#5... Then as I was tightening... at the last
torque sequence... The other one blew out....
(lower right) #8(i am guessin').... So I had to do
that one..... I did that one while the head was still
on...... cut some more rod and threaded it in.
    I ended up only finding grade 7..... rod...
it is 7/16 fine thread.....  I cleaned the debri
out of the the taping with a tiny screw driver
and just threaded it in... It was a little
nerving....  When to decide to stop threading
it in... I did measure carefully, buy still it was
hard to tell when.... It was done.. due to how
it felt..... and well, you only get one try at this....
I double nutted the rod and cranked it in.....
I used the conventional flat washer the was
origininally there and put a lock washer on
top of that.....  It seems to be holding......
   So I believe this occurred due to excessive
heat..... It has been cold here, but I got stuck
in traffic on the highway a couple of times...
and she got hot above the halfway mark.
not into the red but, close... maybe a 1/4
inch away.......  My thermostatic switch
had failed..... so electric fan was not
coming on....  I had ripped out the AC
and the mechanical fan........
     So I think this is a story with a
happy ending..... car is running
good.........  If it fails.... I will
add to this post.....
