My car wont start sometimes please help......
So i have a 2002 Subaru WRX and just recently it began not starting it does not do it all the time but sometimes when i go to start it all the lights will come on and work, but when i press the clutch and turn the key to start it you can hear it just click one time and wont start. It doesn't crank or anything its just a simple click sound...
Another problem I have is that when i turn the head light switch to the off position the headlights will stay on.
Anyone have any idea what could be causing these problems or have a solution to them?
Quite possible the no-start is due to burned/pitted copper contacts in the starter's solenoid.  Rather common problem in older Subies.  Try a search on here for "starter contacts."  It's not too difficult a job and new contacts aren't very expensive.  Good luck.
  • Like 2
Thanks for the help guys but I believe I found my problem. I tore it apart today and here the guy that had it before me when he put a turbo timer in it he spliced a wire for the ignition in about three different spots, and the metal to the crimps he used are loose and exposed. So I hope once i replace the wire here it will work. But thanks for your guys help.
