Rooster2 Posted December 30, 2014 Share Posted December 30, 2014 My wife's 98 Outback needs top hats.Tie rods and ball joints are tight, but when hit a bump with front left, the car will shutter for a split second. It has been this way for a while, but now is getting worse. The front struts are prolly the originals with 166K on the odo, and are still serviceable, but I can tell they are not the best. I checked multiple on line auto parts stores for replacement struts and top hats. KYB struts are what I have bought in the past, but like everything else they have gotten expensive. All KYBs are priced near, or over $100 each from vendors. Add the cost of new top hats, and overall cost is around $325.00. Our 98 Outback is on its last legs. The body is not that good, so prolly only keep for a couple more years. So, I am thinking cheap fix to last a couple of years. In my on line search, I came across Sensen struts. Yea, they are cheap Chinese struts, selling for one third the cost of KYBs. Anyone have experience using Sensen struts?? Will they hold up for a couple of years?? Quote Link to comment Share on other sites More sharing options...
987687 Posted December 30, 2014 Share Posted December 30, 2014 A friend of mine ran sensens and they didn't last all that long. If you don't drive it on really crappy roads full of holes all winter they'll probably hold up fine, though. FWIW, KYB struts are around $60 on rockauto. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted December 30, 2014 Author Share Posted December 30, 2014 A friend of mine ran sensens and they didn't last all that long. If you don't drive it on really crappy roads full of holes all winter they'll probably hold up fine, though. FWIW, KYB struts are around $60 on rockauto. I had gone to Rock auto website, and found it hard to navigate. Returned again per your suggestion, but nothing is listed specifically for Legacy Outback fronts, only Legacy and Legacy GT. I looked for KYB part # KY235633, and KY235632, which is the correct part number, but not found on the Rock Auto website.. Quote Link to comment Share on other sites More sharing options...
upnorthguy Posted December 30, 2014 Share Posted December 30, 2014 Seems like it is just further down in the listing on RA: http://prntscr.com/5morgw I expanded Subaru>Legacy>98>2.5L H4>Suspension>Strut then about half way down in the "Original ride quality" section $71.79 each (plus you can always find at least a 5% off coupon online). 1 Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 2, 2015 Share Posted January 2, 2015 KYB or bust. You're likely to regret the savings by using anything else. The mounts don't typically need to be replaced unless the rubber in them is badly cracked and literally falling out. Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 2, 2015 Share Posted January 2, 2015 KYB's Best deal I get on them is when I find an almost new set in the junk yard. I grab them when I see them $25 each complete, strut, spring and top hat. Amazon or Ebay also has some good prices on KYB strut sets from time to time. Quote Link to comment Share on other sites More sharing options...
Aluxes Posted January 2, 2015 Share Posted January 2, 2015 I found a set of 4 KYB struts on Amazon for 240.00. Check there. Quote Link to comment Share on other sites More sharing options...
