xdeadeye1 Posted December 31, 2014 Share Posted December 31, 2014 I have a 96 legacy wagon, 2.2, Automatic. My drver seat is worn out,,, not very comfortable.. Can anyone tell me what years and models are compatable with my 96? Do impreza seats work? Im going to try to find some in a junk yard, would like to know before I go looking. Link to comment Share on other sites More sharing options...
wtdash Posted December 31, 2014 Share Posted December 31, 2014 (edited) Hi, The easiest plug-n-play are the '90-'99 Seats from any Legacy model....even the Outback. I 'think' the '00-'04 may fit also, but not 100%. You'll need to keep your existing buckles. The '92-'07 Impreza seats will bolt in, but you may sit higher than you like. I know on the '02-'07 WRX models the seats are a good 1-2" higher and even w/the height adjustment (driver's side only) @ the lowest setting they're too high for many. GL, Td Edited December 31, 2014 by wtdash 1 Link to comment Share on other sites More sharing options...
lmdew Posted January 1, 2015 Share Posted January 1, 2015 If its just the foam, grab a passenger side, usually in better shape, and install on the drivers side. 1 Link to comment Share on other sites More sharing options...
idosubaru Posted January 1, 2015 Share Posted January 1, 2015 www.car-part.com I have a pair of tan front leather, electric adjustable, heated seats from 00-04 Outback. Link to comment Share on other sites More sharing options...
Olnick Posted January 1, 2015 Share Posted January 1, 2015 So front seats are not side specific? I never thought of that! Great idea, Larry--thanks! Link to comment Share on other sites More sharing options...
wtdash Posted January 1, 2015 Share Posted January 1, 2015 On 1/1/2015 at 5:07 PM, Olnick said: So front seats are not side specific? I never thought of that! Great idea, Larry--thanks!IncorrectSeat CUSHIONS/foam are interchangeable. Not the whole seat. Link to comment Share on other sites More sharing options...
keith3267 Posted January 1, 2015 Share Posted January 1, 2015 (edited) There are interchangeable if you don't mind the controls on the inside instead of the outside. You can swap the foam pads and covers though. Edit, manual seats only, power seats, not so much. Edited January 1, 2015 by keith3267 Link to comment Share on other sites More sharing options...
wtdash Posted January 1, 2015 Share Posted January 1, 2015 Huh? The rear bases on the seats are side-specific they will not interchange. Link to comment Share on other sites More sharing options...
Rooster2 Posted January 1, 2015 Share Posted January 1, 2015 On 1/1/2015 at 5:07 PM, Olnick said: So front seats are not side specific? I never thought of that! Great idea, Larry--thanks! They are not interchangeable..........as seat belt receptacle is built into the seat. What can be done is to take the foam stuffings from a passenger seat, and install into the driver's seat to make that seat comfortable again. Link to comment Share on other sites More sharing options...
keith3267 Posted January 2, 2015 Share Posted January 2, 2015 (edited) Seat belt receptacles are NEVER built into the seat. But there would be almost no room for the reclining lever if the seats were reversed. Way back in the old days, the few cars that had bucket seats did not have reclining backs so people used to swap them to even out the wear. But it would be such a PITA to do that today that swapping the foam and covers is the only practical way. Just because something can be done (with enough effort) doesn't mean that it should be done. If the seats can't be separated from their tracks, then they cannot be swapped on some cases because the tracks aren't symmetrical. Edited January 2, 2015 by keith3267 Link to comment Share on other sites More sharing options...
pginter96 Posted January 2, 2015 Share Posted January 2, 2015 If you're looking for more support, bugeye WRX seats fit perfectly, that's what I have in my 97. They are nice seats If you can find them in a junkyard, that is... Link to comment Share on other sites More sharing options...
xdeadeye1 Posted January 2, 2015 Author Share Posted January 2, 2015 what is a bugeye wrx? Link to comment Share on other sites More sharing options...
pginter96 Posted January 3, 2015 Share Posted January 3, 2015 On 1/2/2015 at 7:50 PM, xdeadeye1 said: what is a bugeye wrx?Second generation Impreza. 2000-2002. Looks like this (Picture from wikipedia) Link to comment Share on other sites More sharing options...
xdeadeye1 Posted January 3, 2015 Author Share Posted January 3, 2015 So today I went to the local Junkyard. I found they have a 98 outback wagon. I have the 96 non outback version. The seat in it is 5 x better than mine is,, it was oozing support and plush lol They want 35 so I told them I would be back Monday to get it. Anyone think it will be a problem being too high or anything? It does have this extra manual seat height adjustment on the side of the seat. My 96 doesn't have that. Link to comment Share on other sites More sharing options...
wavekayaker Posted January 4, 2015 Share Posted January 4, 2015 You will be fine. I put a set of those in my old Brighton wagon. Very nice upgrade! Link to comment Share on other sites More sharing options...
Rooster2 Posted January 4, 2015 Share Posted January 4, 2015 I have swapped in seats into my 99 OBW with seats from a yard. It is simply an unbolt and rebolt. Suggest you wrap duck tape around the seat "feet" on taking out the old, putting in the new. Without the legs taped, it is very easy to scratch the car body paint. It also helps to flip the seat back forward to make the seat fold up into a smaller package to exit/enter the car. Link to comment Share on other sites More sharing options...
