uniberp Posted January 4, 2015 Share Posted January 4, 2015 (edited) I already replaced the filler tube months ago, no CEL light since then. Until now. Reset lasts a few days. On a 1999 Forester does a 0440 code LIKELY mean the purge control solenoid? Or the pressure control solenoid? The Haynes Legacy manual says I have to drop the tank to get at one of the solenoids, but there are 2 electrical connectors right near the vapor canister by the right rear fender so I assume one is vent and one is purge. It looks like one of the small vapor lines over the rear crossmember might be rusted. That looks like a joy to get at. Edited January 4, 2015 by uniberp Quote Link to comment Share on other sites More sharing options...
keith3267 Posted January 4, 2015 Share Posted January 4, 2015 I find that a lot of times the evap codes are often caused by chronic overfilling the gas tank. IF that is the cause, then it is usually self curing by simply stop filling at the first click. If that is not the case, then either the purge valve or the canister has to be replaced. However, it the vent line is rusted through and has a leak, that could be the issue. Instead of replacing the line, I would just cut it and slip a tight fitting rubber hose over it. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 5, 2015 Share Posted January 5, 2015 The purge control solenoid is under the intake manifold. The two at the back that you're seeing I'm not sure of the names, but one of them could be the vent valve. The solenoids are not typical causes for this code. If you can see that the vent line is rusted, that's probably the cause. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted January 5, 2015 Share Posted January 5, 2015 Suggest you replace the gas cap to solve your 0440 code problem Your current gas cap may not be sealing properly. This has worked for me in the past. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 5, 2015 Share Posted January 5, 2015 Inspect the fill tube behind the little plastic guard. Dirt and salt accumulate there and the fill tube is subject to corrosion. I pinhole rust hole can cause this. Perhaps some epoxy to cure it. Ditch the plastic cover if so. Quote Link to comment Share on other sites More sharing options...
