mporto Posted January 5, 2015 Share Posted January 5, 2015 I need to find out how to take out the ignition switch from my 1979 Subaru DL Wagon. If anyone can help me I would appreciate it. thank you. Link to comment Share on other sites More sharing options...
moosens Posted January 5, 2015 Share Posted January 5, 2015 Remove the column cover , grind or drill out the rivet heads , or use a chisel to turn them like a nut because they ARE threaded. Disconnect plugs and you're done. Are you replacing the key core or the contact plate (switch) ? 2 Link to comment Share on other sites More sharing options...
nipper Posted January 6, 2015 Share Posted January 6, 2015 I just usually drill out the rivet heads. Its not that bad a job. Link to comment Share on other sites More sharing options...
