Roll call for lifted Soobs 2015. Gallery thread, no chat.
ezapar
1985 GL Wagon 4WD
EA-82 With Weber 32/36
5-Speed Dual Range
6" JAW Lift
235/75/15 Maxxis Bighorns on Allied Daytona Wheels
6-Lug Conversion
Welded Rear Diff with Extended Diff Breather
Yakima Load Warrior with Extension
6" Old School KC Daylighters
Maxima Alternator
Cobra CB Radio and 4' Firestick Antenna
JVC Stereo
Custom Built Tube Bumper
24" LED Flood/Spot Lightbar
Front 12 Blade Fuseblock
Rear 6 Blade Fuseblock
Interior LED swap
Lots of other small stuff
Edited by Vegablade
  • Like 6
  • 4 weeks later...
84 wagon w/8" lift
EJ22 OBD I
EA82 5spd D/R
Dual E-brake
Long travel rear suspension
Rear Disc
CB
Roof Rack
31x10.5x15 Mud Rovers on redrilled Isuzu rims
Axle Folley:P1010020.jpg
84 factory 4wd sedan
Sunroof, PS, PW, Cruise control, A/C
1-1/2" front end lift
96 Outback Heated seats
CB
Pheonix......Rolled rally style....roof collapse was not as bad until whinching it over it got mangled.....She had just turned 300K....Gone now to the crusher.IMG_1184_zpsa050232f.jpg RIP
And introducing, Mr. Stee,............ Eck Stee
Non-turbo 89 XT 4cyl 4wd, now Fulltime w/difflock
Sach's EA82 adjustable front 4wd wagon struts, front. Cranked about halfway
Front crossmember, trans dropped w/outback spacer 1-1/4"
2" Rear shock lift
205/65/15 Nokian Studded Snow Tires on redrilled toyota rims.
And Miss Cleo
87-1/2 XT turbo on a custom Isuzu/Subaru frame
N/A ea82 mpfi, 5spd d/r with welded transfer collar.
Nissan 720 2:1 divorced transfer case
86 trooper front suspension, hubs and brakes, running Subaru diff and hybrid Isuzu/Subaru axles
4.11 diff welded
Subaru ea81 rear suspension w/ 4.11 diff welded (front hubs unlock for hi traction areas)
33x12.50 BFG tires
Edited by Gloyale
  • Like 1
My old 86 brat
Fuel injection
Rear discs
LTD rear diff
Adjustable EA82 front struts
Xt6 seats
5spd dual range
And a bunch of other stuff
My 1990 loyale
EJ swap in process
4" Allied lift with camber correct front blocks
Rear discs
Gl-10 interior
king springs
yakima load warrior
and other stuff
1604777_589342354473256_974644506_n_zps7
02 outback sport
forester struts
05 wrx interior
906701_450162461724580_1030875952_o_zps9
79 Brat
EA81
4 spd dual range
ea81 front and rear crossmembers and suspension
lift
Other stuff
Edited by bratman18
  • Like 1
I suppose I will include a "under construction" pic of my 78 brat.
Eventual specs will include:
EJ22
5 speed DR
6/7" lift
EA81 front and rear suspension
-heavily reworked for more travel
27-29" super swampers,havent decided yet
modernized wiring
rear mount radiator
rear mount battery
rear mount spare tire
rear mount tool box
As you can see,I have alot to do still,but today I finally got the adapter plate back from the machine shop so soon I will be able to start test fitting the engine and mocking up the long travel modifications to the front suspension.
DSC00425_zps7144698a.jpg~original
  • 2 weeks later...
Stella - '97 Impreza Outback Sport
Stock 2.2 Frankenmotor with EL headers and intake spacers
4.44 Auto with VLSD Welded Rear
235/75/15 BFG Mud Terrain KM2's
7" Strut / 5" Body Lift
Rock Sliders
Tube Bumper and Rear Tire Carrier by Monstaru
Edited by NorthCoast
  • Like 5
  • 2 weeks later...
1986 Gl Hatchback.
6" Sjr/ BOSS/Home made lift.
5 speed w/ welded 3.9
Rear discs
Fogs & CB with PA
27" swampers on Pugs.
Weber
Steel bumpers
Maxima Alternator
Front seats from 80s Nissan 4wd pickup.
Nothing special just a reliable ol ea81 with a lift.
http://i1340.photobucket.com/albums/o739/thedabdoctor/Mobile%20Uploads/0307151334_zpsobvo6dm4.jpg
  • Like 3
  • 4 weeks later...
  • 4 weeks later...
1994 Loyale
EA82 - 192k & going strong (i have no clue how)
4 Inch lift
235x75x15 mud terrains
6 lug conversion
honda rear springs
dual range
welded diff
rear disks
sparco drivers seat
front ram bar
Edited by nick1208
  • 2 weeks later...
2003 outback
Front and rear leaf springs and solid axles
Ej25
Toyota r151f with dual t cases 4.7:1 gears in rear case
Triple shifter
Full hybrid cage mostly exo with partial internal
Toyota based diamond axles at 65" wms to wms
5.29 gears front and rear
Disk brakes front and rear
Full float rear axle
20 gallon fuel cell in trunk
32" light bar tied into reverse lights
Stainless steel(eBay) headers customized for solid axle swap
2.25" full exhaust
Rollin on 30s in the pictures but have a set of 38.5x14.50r15 tsl sx to be mounted on 15x10
  • Like 2
  • 1 month later...
My 98 Forester S
2" front, 2.5" rear ADF lift
Yakima loadwarrior roof basket
Factory rush guard
Rockblockz mud flaps
JDM front grille
215 70 16 Grabbers
Painted oem wheels with 1" spacers
Trailer hitch
JDM STi carbon fiber upper strut brace
  • Like 1
  • 2 weeks later...
86 hathcback
-6" lift
-tires are 235/75/15's
-ej22 swapped with 91 ob1 harness
-5 speed d/r
-3.9 clsd in the back
-rear monroe shocks are for a f-350
-ea82t front end (spindles, hubs, brakes, struts, cross member, steering rack, control arms, ect.)
-rear disks
-6 lugged hubs
-custom rear bumper found in junkyard
-cut down semi trailer mud flaps
-factory brush guard
-cherry bomb glass pack
-lengthened drive line iirr 9" eventually i need to get a shop to weld my ends to a new piece of tube eventually...
  • Like 2
  • 1 month later...
  • 3 weeks later...
This topic is now closed to further replies.
