pheebs314 Posted January 7, 2015 Share Posted January 7, 2015 I had a bit of a collant leak so I decided to be cheap and use the easy fix... stop leak! So far it appears that my problem isn't and I'm leaking other stuff now too. I've got an oil drip I didn't have (or at least didn't notice) and another unknown substance. Its thick and slippery and tan (maybe stop leak?) But its dripping from the driver side just behind the tire. My car is running fine. Keeping a good temp and its smooth too. Any ideas? Link to comment Share on other sites More sharing options...
MilesFox Posted January 8, 2015 Share Posted January 8, 2015 the small hose under the manifold from the thermostat to the top of the block. 1/4" size hose. do not use fuel line. this will drip onto the top of the block and run off the back of the engine. alos inspect the lower hose where the metal pipe attaches to the water pump. replace the o-ring. Fix hoses as stop leak does nothing unless the radiator itself has a pinhole leak. Link to comment Share on other sites More sharing options...
pheebs314 Posted January 8, 2015 Author Share Posted January 8, 2015 I actually figured it out. My over flow tank over flowed and dripped down through the engine compartment. It was a mix of stop leak and coolant. Link to comment Share on other sites More sharing options...
DaveT Posted January 8, 2015 Share Posted January 8, 2015 There are a total of 7 coolant hoses on an EA82 engine. If one is old enough to fail, they all are ready to go. Replace all of them. Be sure to use hose specified for coolant. Link to comment Share on other sites More sharing options...
pheebs314 Posted January 8, 2015 Author Share Posted January 8, 2015 It isn't a hose. Mine are new with a new water pump. The gasket I think just went. Link to comment Share on other sites More sharing options...
DaveT Posted January 8, 2015 Share Posted January 8, 2015 Watch the coolant and that tank closely. Check it every time you are going to start the car. Check that the cooling system has no air by squeezing and releasing the upper radiator hose rapidly. You should hear the jiggle pin, not air. Link to comment Share on other sites More sharing options...
