gettin hot.
my 89 spfi wagon has started gettin hot while driving, when I slow down it cools down, never over heats but it gets up there. I suspect if I ran the highway and didnt run the heater it would over heat.
I know my water pump is failing, it leaks occasionally from the weep hole. but it should still be circulating coolant
coolant is full.
no mixing of coolant and oil
no bubbles in rad while idling.
no steam from exhaust
could it just be the water pump failing
i doubt the rad clogged but i think i have a spare i can put in.
when i swapped the motor i flushed the whole system and it was all flowing freely. this was about 3mo ago
any ideas?
Edited by AKghandi
thats kinda what I was thinking, but i dont know how the rad could have clogged, the cooling system has been cleaned and filled with fresh coolant.
with my other wag, half the rad was clogged and it would run down the highway just fine.
i will be replacing the water pump tomorrow hopefully that cures it
It probably is just the water pump. My mom's Taurus had the same problem, it weeped and would get hot when driving. Replaced it and it was fine. The other thing you can look for is a sticky thermostat. If it's only opening half way or partially that could be a problem too.
you did all three things together so now don't know exactly what the cause was :( but, so many times it can just be a pooey old radiator cap - often the original just give up after 20 years or so.They are a service item and lucky for us the originals or genuine are of such good quality, most don't even think of replacing !
+1 for the update
