5 Speed TOP STARTER Gearbox for EA71 engine, with 3.7(10-37)CWP
In my service manual it calls them "5GM" , but I think you are asking for the production code which would be on a foil sticker on the transmission by the bell housing. Sound correct?
Info you may or may not need:
1st gear 3.666
2nd gear 2.157
3rd gear 1.464
4th gear 1.029
5th gear 0.789
thanks moosens.
only this 5speed gearbox is equipped with the 3.7 ???
what other models are equipped with 5speed with 3.7 CWP ????
the "5GM" is sticked on the gearbox ???
where exactly on the bellhousing is appeared the code ???
this one,you mentioned above,came from what model ???
Only the "FE" model here in the USA came with 3.70 as best as I can tell. The other five speed were 3.90 or 3.889 to be exact.
Here the FE was a fuel efficient model with higher compression , different cam , and a taller 2nd and 5th gear in them. Perhaps you have a similar model?
The small foil sticker is located at the side/top of the bel of the transmission. I have seen various editions but they all begin with T. When I dig up a parts manual I will have more info for you.
That code 5GM is simply used to express a five gear manual. The true production code which identifies specifics is in that sticker.
What model is the car this tranny is from?
I have most of my manuals in storage. I will try to help but hopefully someone else has them handy.
