where do these gaskets go?
Okay I'm just curious I'm almost certain I don't need these for my RX Turbo EA82
I'm just curious I'm not even familiar with these gaskets on any ea82 engine
If you could tell me where they going what they are that would be awesome thank you guys
Upper left is a Hitachi carb base gasket and the upper right is a tbi gasket. No clue on top center or bottom two.
I thought the TBI Gasket was more like an o-ring type of material?
I see if anybody else can play the guessing game lol
Confirming what Caboobaru says above, the bottom two green ones are the coolant transfer gaskets on the lower back section of mpfi inlet manifold  (maybe not spider specific) - very handy for when you replace those small 12 & 14? mm welch plugs at the back.
The large green one looks like spider TB to inlet manifold gasket - they are not same as mpfi non spidey
Edited by jono
www.google.com
EA82 spider manifold image
shazam!
came on XT turbo and some others ? Looks more an EJ style of inlet manifold over the old shar[p angle old mpfi EA82 inlet.
It is a 4 legged spider not got 8 legs !
Edited by jono
www.google.com
shazam!
Oh yeah I knew that Like I said I was brain farting the older Impreza they had the 1.8 right
I have never seen an XT with that motor I've seen them with the EA82 to multiple fuel injected
Like what's in my 86 rx
