peoplecallmele0 Posted January 23, 2015 Share Posted January 23, 2015 Ok so here is the story, I have a 2000 Subaru Legacy GT Limited with 93000 miles Automatic Trans. Some months ago I noticed that when I would change from Park to Reverse the trans would thump real loud, but for some reason the harder I would be pressing the bbreak the lesd it would thump so I ended up taking it to a friend who lifted it up and noticed that one of the mounts was actually broke so he suggested I replace it. I replaced the mount and the problem stopped for a little but it then started happening again bit by bit and now it's really bad again. AND to top it all off now when the car changes gears it kind of Jerks at times, and some days ago when I was driving the AT Oil Temp light started to flash. no specific pattern or long pause or short/long flash just continues to flash at about the same rate as the turn signal. if anyone has any info on the matter any help would be greatly appreciated Link to comment Share on other sites More sharing options...
CNY_Dave Posted January 23, 2015 Share Posted January 23, 2015 http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/44383-199-2004-how-read-diagnostic-trouble-codes-dtcs.html will let you get trouble codes from the trans with no reader. Link to comment Share on other sites More sharing options...
