Dave643 Posted January 28, 2015 Share Posted January 28, 2015 Hey Guys - long time since I've posted here - My '95 Legacy Brighton has developed a oil leak - a quick look and I found a puddle of oil on the passenger's side of the motor, on the top more towards the back....Won't have time to investigate fully until the weekend - any ideas? 2.2 with 247,000 on the clock.... Link to comment Share on other sites More sharing options...
lmdew Posted January 29, 2015 Share Posted January 29, 2015 Only thing that is on top is the Oil Pressure Sender at the front under the alternator. Oil will travel. Link to comment Share on other sites More sharing options...
Gloyale Posted January 29, 2015 Share Posted January 29, 2015 Power steering leak can look like that too but will be red (ATF) Link to comment Share on other sites More sharing options...
heartless Posted January 30, 2015 Share Posted January 30, 2015 i second the oil pressure sender unit at the front. Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted January 30, 2015 Share Posted January 30, 2015 Oil pressure sender is #1 culprit, but also check the PCV tube connector, back of the block, by the pass. side of the throttle body. ~ 7/8" in diameter. I've seen these pop off or weep, but usually is followed by poor running and is slow to accumulate. Link to comment Share on other sites More sharing options...
Dave643 Posted February 2, 2015 Author Share Posted February 2, 2015 Oil pressure sender replaced - cleaned up the motor as best as possible in the middle of winter - I'll let you all know if this fixed the issue Link to comment Share on other sites More sharing options...
