AnAmericanNCO Posted February 2, 2015 Share Posted February 2, 2015 (edited) On Subaru models, what can damage the ABS tone ring that is mounted to the CV Joint ? The question came up at work by another Subaru owner, of which I was asked if rust and corrosion can cause the ring gear to crack ? I answered him that it could be, but that I would ask on the forum. Edited February 2, 2015 by AnAmericanNCO Quote Link to comment Share on other sites More sharing options...
upnorthguy Posted February 2, 2015 Share Posted February 2, 2015 A hammer, a Sawzall, rust... Are you having an ABS issue (e.g. ABS light on)? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 2, 2015 Share Posted February 2, 2015 generally it's better to tell us exactly what is happening - what symptoms do you have - what lead to inspecting the tone ring to begin with, etc. tell us what year/model you're talking about. if the tone ring is mounted to the CV then I suspect this is 2000+ something? someone working on it in the past may have damaged it. a bad wheel bearing can damage the former hub fixed tone rings. Quote Link to comment Share on other sites More sharing options...
