subinewby Posted February 2, 2015 Share Posted February 2, 2015 I took the coupe out muddling the other day and was on my way out of the mud going up a slight hill had it in 2wd and heard a snap and it was just spinning. So I put it in 4 hi and made it home. I'm in Texas and there's not alotta Subaru mechanics. What do y'all think it might be that I need to fix. Any help is appreciated. Link to comment Share on other sites More sharing options...
ihscout54 Posted February 3, 2015 Share Posted February 3, 2015 Broke an axle or stripped hub. Link to comment Share on other sites More sharing options...
SuperBrat Posted February 3, 2015 Share Posted February 3, 2015 (edited) Yep agree........ stripped hub probably on passenger side Edited February 3, 2015 by SuperBrat Link to comment Share on other sites More sharing options...
Beaudean Posted February 3, 2015 Share Posted February 3, 2015 Or you snapped the rollpin. If so most likely it's the on the passenger side. Hopefully it's not a striped stub shaft. Link to comment Share on other sites More sharing options...
subinewby Posted February 6, 2015 Author Share Posted February 6, 2015 Ok thanks guys. I thought it might b a hub Cus that's happened before I'll check it out this weekend. Appreciate the responses. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted February 6, 2015 Share Posted February 6, 2015 If you stripped a hub the cause is often a loose axle nut (the washers have to go on a certain way to keep it right properly) At least that was the case on my 87. Link to comment Share on other sites More sharing options...
