98 EJ25D w/ 97 Impreza L Trans & Clutch Question
Clutch is fine. Everything is the same and will bolt right up. Different cars came with different final drive ratios and that must be a match between the trans and rear diff.
The general rule is that Legacy Outback , GT and Impreza RS are the same (4.11). And Impreza (Non RS and Legacy non GT or Outback) are the same. (3.90)
http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru%20Transmission%20Chart
Match the trans codes to the chart to see what yours is and what potential donors are. Gearing can be different but the final drives must match. Or swap a matching rear diff as well.
Edited by AdventureSubaru
your name cracked me up. lol.  I have the rear diff from that impreza as well, so i should be fine right?
