its_masters Posted February 4, 2015 Share Posted February 4, 2015 Would i still use the proper clutch for the EJ25D that i would normally if i have a 97 Impreza L Trans installed? Or would i have to go a different route? Also, will this trans mount up to my drive axles and rear drive axle? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted February 4, 2015 Share Posted February 4, 2015 (edited) Clutch is fine. Everything is the same and will bolt right up. Different cars came with different final drive ratios and that must be a match between the trans and rear diff. The general rule is that Legacy Outback , GT and Impreza RS are the same (4.11). And Impreza (Non RS and Legacy non GT or Outback) are the same. (3.90) http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru%20Transmission%20Chart Match the trans codes to the chart to see what yours is and what potential donors are. Gearing can be different but the final drives must match. Or swap a matching rear diff as well. Edited February 4, 2015 by AdventureSubaru Link to comment Share on other sites More sharing options...
its_masters Posted February 4, 2015 Author Share Posted February 4, 2015 Clutch is fine. Everything is the same and will bolt right up. Different cars came with different final drive ratios and that must be a match between the trans and rear diff. The general rule is that Legacy Outback , GT and Impreza RS are the same (4.11). And Impreza (Non RS and Legacy non GT or Outback) are the same. (3.90) http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru%20Transmission%20Chart Match the trans codes to the chart to see what yours is and what potential donors are. Gearing can be different but the final drives must match. Or swap a matching rear diff as well. your name cracked me up. lol. I have the rear diff from that impreza as well, so i should be fine right? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted February 4, 2015 Share Posted February 4, 2015 Yep. swap them both and you're golden. Link to comment Share on other sites More sharing options...
its_masters Posted February 5, 2015 Author Share Posted February 5, 2015 Yep. swap them both and you're golden. Perfect. Thanks a lot! Link to comment Share on other sites More sharing options...
