lmdew Posted February 7, 2015 Share Posted February 7, 2015 I got a 98 Impreza Sedan with a 2.2. The darn rabbits had fun eating plug wires and into the harness. I replace the plug wires and coil (4 pin) but there is still damage to the main part of the harness. As soon as I start it the cooling fan starts and it throwing P0117. I can clear the code, the fan turns off as the CEL goes out, but comes on in a second or two. I have several other intakes but none of them are an exact match. The 98 Impreza: - 4 pin coil plug - Power Steering Pump plug - No EGR The other harness I have: - 3 pin coil plug, I have the correct 3 pin coil to work with the wires - No Power Steering Pump plug - Has an EGR So is I just swap the harness and use the 3 pin coil, and leave the Power Steering and EGR unplugged will it work without setting CEL? Thanks, Larry Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 7, 2015 Share Posted February 7, 2015 Nope. Its a 98 with the 4 pin coil? What's the build date? Does it have an igniter on the firewall above the pitch mount? Link to comment Share on other sites More sharing options...
lmdew Posted February 7, 2015 Author Share Posted February 7, 2015 98/08 Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 7, 2015 Share Posted February 7, 2015 That's a late build date. I would think its a 99MY with that build, which would make more sense for the wiring change. What's the VIN? Link to comment Share on other sites More sharing options...
lmdew Posted February 8, 2015 Author Share Posted February 8, 2015 Yep, 99 I think. Only one wire going to the temp sensor was chewed through, so I repaired it. Lot's of work to get the harness off. - Power Steering Pump - AC Compressor - Intake It's almost done. Thanks Link to comment Share on other sites More sharing options...
