help, snapped bolts
So, trying to reinstall some parts back onto my car now that I've got a garage with a roof height that's not ridiculously short.
Tailgate struts back in, but snapped one of the lower bolts just above the tiallights.
And another that holds the bonnet (sorry, hood :P) onto it's hinges.
Can't get vice grips onto either. Any suggestions?
I'm pretty sure you can get left hand drill bits from MScdirect.Com or McMaster carr. If the bolts snapped because they were hard to turn while unscrewing, drilling out is what you will likely end up doing. Another trick I've seen is weld a washer to the snapped end, and use it to turn the bolt.
