Dinky26 Posted February 8, 2015 Share Posted February 8, 2015 Could not get the lights in the bumper on, bunch of corrision in socket figured that was the issue. Bought a buffing wheel for the Dremel got them all clean an pretty, still no go.. Had to go buy another circuit tested since the gremlins hide my other one, got the one that tells which leg is negative, glad I couldn't find mine, turns out both legs are positive, where do I find the origin of those wires? Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 9, 2015 Share Posted February 9, 2015 Aren't those just blinkers dude? If this is a loyale or gl the marker lights are the corner lights next to the headlights. Maybe you are working on something else? 2 Quote Link to comment Share on other sites More sharing options...
Dinky26 Posted February 9, 2015 Author Share Posted February 9, 2015 (edited) Well, the way my brain has been going lately that could very well well be the case. That being said one of those should be negative should it not. This is the 86 Brat GL Edited February 9, 2015 by Dinky26 Quote Link to comment Share on other sites More sharing options...
pksjeep Posted February 9, 2015 Share Posted February 9, 2015 Try touching a piece of wire to the light housing and a good ground on the car with the lights on. If it comes on you have a bad ground. . I am guessing the two hot wires are : lights and blinker. Quote Link to comment Share on other sites More sharing options...
Dinky26 Posted February 9, 2015 Author Share Posted February 9, 2015 Okay, will mess with again when I get home. Quote Link to comment Share on other sites More sharing options...
Dinky26 Posted February 9, 2015 Author Share Posted February 9, 2015 Yep, another SPECIAL MOMENT for me today, Aren't those just blinkers dude? If this is a loyale or gl the marker lights are the corner lights next to the headlights. Maybe you are working on something else?you were write RIGHT those are the blinkers. Some days I should wear a helmet.???????????????? 1 Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 9, 2015 Share Posted February 9, 2015 Hey, at least you can admit your mistake! It happens to everyone every once in a while. I don't know much about the second gen brats but I did know the gl's and loyales the blinkers are down there! 1 Quote Link to comment Share on other sites More sharing options...
Gloyale Posted February 9, 2015 Share Posted February 9, 2015 Brats/hatches/EA81 wagons etc.....they do have a marker on the side of the front bumper......small bulb. And both legs are not positive. You are seeing a backfeed from the marker on the other side. Quote Link to comment Share on other sites More sharing options...
