tranny stuck In third...WTH?
Yeah fellas, I've tried all of the above. It's happened before if I let the car stop with the shifter in third gear. But now it won't release from 3 regardless. Wondering if maybe the synchro ring came apart and is jammed in the works? Starting to think it's a lost cause and should be replaced outright....
Thats what mine did. For a while it would kindof hangup in 3rd, but with enough force would pop but ...then finally it was stuck stuck. I replaced it with a 5speed.
Thats what i recommend....the gear spread on the 5 speed is sooo much better than the 4 speed.
  • Like 1
  • 7 months later...
options:
swap the transmission. steamboat springs has one for $150 for a 1981 Hatch:   970-879-8178
do you mean "it's stuck in 4th" or the shifter will physically only go in 4th gear.  i'm not sure there's much practical difference as i'm not a trans expert, but i have a time or two seen a car stuck in gear that was the fault of the clutch...maybe i wasn't trying hard enough but a new clutch has fixed a shifter that won't come out of gear.
VWtech - you're not going to have time for transmission R&R between all those ECU reflashes are you?! lol
Yep,  listen to the above.  Most like your synchro is has hung up.  You can try removing the linkage and shift boot covers and tapping the base of the shifter with a rubber mallet.  I did this and it popped out.  I replaced the oil with good synthetic and haven't had a problem.  That does not mean it is a guaranteed fix because the problem is still there.
Just my opinion might be worth trying.
Good Luck
  • Like 1
