Suba_GL_87 Posted February 19, 2015 Share Posted February 19, 2015 hey! ej22 is running! but upper and lower hose cannot fit to engine from GL's radiator. I have 2 of 1 1/2" adapter pipe for coolant hose. so, it's good idea use tin weld for pipe on steel or alum radiator? any advised! thanks. Link to comment Share on other sites More sharing options...
Scooner Posted February 19, 2015 Share Posted February 19, 2015 You could also just get universal flex hose as well. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted February 19, 2015 Author Share Posted February 19, 2015 will be bent hose.. Link to comment Share on other sites More sharing options...
skishop69 Posted February 20, 2015 Share Posted February 20, 2015 You can't weld steel to aluminum. Not with any reliability. You'll need to find hoses that fit. That means taking a coat hanger, bending it to match the hose routing and then taking it to a parts place that will let you in back to peruse their hose collection. Unless someone here already knows what hoses you need. Link to comment Share on other sites More sharing options...
wagonist Posted February 20, 2015 Share Posted February 20, 2015 The other trick is to get the GL radiator hose, cut it on the straight after the first bend off the rad, do the same for the EJ hose off the engine Get an exhaust shop to get a piece of pipe in the smaller size & flare it to match the bigger pipe. Use copper pipe as it's easier to stretch with less heat. Exhaust shop may already have a flaring type pipe. if so, Get them to weld on straight pieces as required, and also get them to run a bead around the outside edge so the hoses don't pull off. Link to comment Share on other sites More sharing options...
Crazyeights Posted February 20, 2015 Share Posted February 20, 2015 Ej22 in an EA82 body? I am pretty sure that I used stock Legacy hoses with Napa 1 1/4" - 1 1/2" hose adapter fitted inside a NEW hose with urethane window adhesive. Many miles and no problem. I have pics if needed in the "Royal Loyale" thead. Link to comment Share on other sites More sharing options...
