odd problem, request help from other experts
ok- so im not a noob, been working on subarus professionally for 16 years- but sometimes a problem needs other ears and eyes
a friend has a 2002 outback with a sohc 2.5 and 5 speed
it has about 20k on a complete rebuild, bearings the works, 200 on the car
when i rebuilt it i installed a mild set of delta cams, a header, thats it
thing runs like a scalded dog
but- he has a 700 mile commute, sets the cruise at 70-75 and it will randomly try and accelerate, and slow down, without driver input.
it does it with and without the cruise on
when he reduces speed to 60-65 it will not do it as often, maybe once in 200 miles
randomly it will stutter and hesitate, occasionally it throws a random misfire, nothing consistent, and randomly it will throw a po172
i have checked for vacuum leaks- none. i replaced the oem fuel pump last week and he noted an improvement everywhere, but problems occurred three times in 700 miles
he noticed it happens more often at half tank and below, as opposed to full tank
help please and thank you
Very possibly the cam grind.  If it was done at Delta Camshaft, Scott can probably tell you which grind it has.  Some are better for low end torque, some for constant high rpm...but all will usually produce a loping idle and as a side effect, a "hiccup" at constant speeds.
Afterthought: have you checked the O2 sensors?
  • 2 weeks later...
You almost have to put a scanner on it and see what the computer is seeing and doing.
If plugs look OK and fuel pressure is good, the answer is probably going to be a sensor dealing with fuel that's out of range. MAF/MAP or O2 sensor. TPS maybe?
So what happens if you try to hold the gas pedal at 70-75 and not use cruise?
Is it predictable enough that he can loosen the gas cap after it happens to see what the car does. This may throw a code (loose gas cap) but ignore it for now.
I don't like you.  :P
I'm going back to a flaky knock sensor. You can watch the engine timing with a scanner, or  if you can get it cheap enough just swap it out. I rarely suggest just swapping out a part but its not a lot of money. Flaky TPS is also possible.
Edited by nipper
Wondering about the cruise and throttle cables/throttle body - something compromised might cause drift up or down via the throttle body/cabling?
I had a non-starting 2001 EJ25 with no engine codes and no known issues.  I swapped the entire intake manifold and it ran beautifully.  How's that for terrible diagnosis and not at all helpful!?!?!?
when it does it (with and without the cruise control on) is there a corresponding movement in the gas pedal?
how significant of an increase/decrease are we talking.  a tiny bit, noticeable, or a lot?
Last resort guess work:
$10 ebay knock sensor, swap crank and cam sensors, MAF, TPS to test.
swap the entire intake manifold
swap in an EA81
