Tighten the cylinder head bolts as follows:
  1. Step 1: Torque all the bolts in sequence to 22 ft. lbs. (29 Nm).
  2. Step 2: Torque all the bolts in sequence to 51 ft. lbs. (69 Nm).
  3. Step 3: Loosen all bolts in sequence by 180 degrees, then loosen an additional 180 degrees.
  4. Step 4: Tighten all bolts in sequence: 40-45 degrees.
This is the information I found online for my 1999 SOHC engine. I have dealt with a few head gasket jobs and the torque specs were somewhat higher and I never had to loosen all bolts 360 degrees in two steps. I broke a 1/2 inch drive ratchet that i needed to use a cheater bar on to get the head bolts loose because the were very tight so these specs just don,t sound right.  What do you people  think?
Thanks
No that's not correct.
The loosening step is correct, but the final torque sequence is not.
Tighten all bolts in sequence to 21 ft-lbs
tighten to 51 ft-lbs
Loosen all 180 degrees
Tighten bolts 1 & 2 to 25 ft-lbs
tighten bolts 3-6 to 11 ft-lbs
tighten all 90 degrees
tighten all an additional 90 degrees
Put a small amount of engine oil on the end of the threads and on the washer.
