I want 120hp from my EA 81 for an airplane, total weight muse be <200lbs.  I don't want the complexity of a turbo.
So, should I use a use a supercharger [which one?]; bore [re-sleeve] & stroke it for low rpm direct drive, or modify for high rpm reduction drive?
RAM 115A is a EA81.Its looks like they upped the compression ALOT(requires 93 octane gas, verses a standard ea81 that is quite happy on camp fuel),Then it is fuel injected.I don't think they bored or stroked the engine though.
So try 11:1+ compression,a cam that makes power around 5K rpm,then adapt a EJ18 MPFI and computer to work on it.
