Transmission overhaul kits?
Hi all,
So I'm trying to source a rebuild kit (bearings and brass) for my d/r 5pd 3.7FD transmission.
I can't find sh*t for kits online.
Also, I swear someone once told me there was a transmission place in southwestern Washington that did Subaru transmissions, exclusively.
Any help in finding a rebuild kit so that I can do it myself, or pointing me to a local (PNW) shop that does good work at a reasonable price would be great!
Thanks!
Edited by wilsonjacob8
You aren't likely to find a complete "overhaul kit" for this transmission in the normal sense. I have had many of these apart including some custom builds and even a swap to 3.9 ratio. What type of problems are you having that would warrant a rebuild ? It could be just a bearing or two. I usually do the 1st and 2nd gear synchros as well as all of the seals.
  • Like 1
Mainly just 216,000 miles of unknown maintenance from previous owner(s), expected leakiness, first gear grinds, finicky when cold, and input shaft play.
I rebuilt the engine, so naturally I want to eliminate the next gaping stability gap.
I will start looking for a good core, then :)
