Any ideas for removing a big suspension bolt that is seized in the rear lower control arm? I've soaked it on PBBlaster overnight and have used an air ratchet and a breaker bar and tried driving it out from the other end. Before I try removing the whole control arm, any garage tricks I should try?
Perhaps some heat? Legacy, right? Is this the long bolt on the lower part of rear suspension? Those can be a pain. You might have to pull the trailing arm with it and work it over out of the car. Someone from the "rust belt" might come along with a better solution too.
Edited by Crazyeights
