oldgoatdude Posted March 1, 2015 Share Posted March 1, 2015 how do you get the clutch cable out from under the dash? Link to comment Share on other sites More sharing options...
Whatever Posted March 1, 2015 Share Posted March 1, 2015 (edited) There's a clevis pin that goes through the pedal and the end of the cable. The pin won't come out without sliding the pedal away from the pedal shaft. There is a locking ring on the end of the shaft that you need to pry off with some decent pliers to slide the pedal. The locking ring on the end of the pedal shaft looks like a washer, but it's not. This is for an ea81 by the way. Edited March 1, 2015 by Whatever Link to comment Share on other sites More sharing options...
lilySapphire Posted March 19, 2015 Share Posted March 19, 2015 Did you take pics? I may need to do this and the Haney manual always needs additional info. Link to comment Share on other sites More sharing options...
Sapper 157 Posted March 19, 2015 Share Posted March 19, 2015 http://www.ultimatesubaru.org/forum/topic/152014-ea81-clutch-cable-what-the-hell/ In this fourm you should find all the info you need. Go down to almost the very bottom and youll see a post with pics attached and a walk thru Link to comment Share on other sites More sharing options...
