clutch cable replacement
There's a clevis pin that goes through the pedal and the end of the cable. The pin won't come out without sliding the pedal away from the pedal shaft. There is a locking ring on the end of the shaft that you need to pry off with some decent pliers to slide the pedal. The locking ring on the end of the pedal shaft looks like a washer, but it's not.
This is for an ea81 by the way.
Edited by Whatever
  • 3 weeks later...
