zegiares Posted March 11, 2015 Share Posted March 11, 2015 What is approximate cost of timing belt replacement? I have heard that the water pump should also be replaced at that time. Link to comment Share on other sites More sharing options...
Legacy777 Posted March 13, 2015 Share Posted March 13, 2015 Welcome to the USMB. If the XT has a timing belt change around 100,000 miles, then yes I would probably also change the water pump as well. I'm not sure on the costs, but maybe others can chime in. Link to comment Share on other sites More sharing options...
Rooster2 Posted March 13, 2015 Share Posted March 13, 2015 On 3/13/2015 at 2:40 PM, Legacy777 said: Welcome to the USMB. If the XT has a timing belt change around 100,000 miles, then yes I would probably also change the water pump as well. I'm not sure on the costs, but maybe others can chime in. +1......fully agree. There is minimal amount of extra labor needed to install a new water pump, at the time of timing belt replacement. It is preventive maintenance money well spent to know that you have a fresh new water pump in your car, vs an old water pump with 100K miles on it, that could crap out at any time. Link to comment Share on other sites More sharing options...
Dj7291993 Posted March 14, 2015 Share Posted March 14, 2015 About 5 hours labor (don't know what rates are where you're at, here they're around $100/hr). Plus parts. The 97 Legacy I just did came to about $1100 for water pump, timing belt, tensioner, idlers, cam seals, crank seal, labor and coolant. Do NOT skip the pullies (idlers and tensioner). I've never seen the belts on an EJ engine break, but I've seen those bearings give out. That's why the 97 was in our shop. Link to comment Share on other sites More sharing options...
