I finally got my car running, and took it for a drive. Here's what my problem is:
* My car idles really low, and it will die unless I give it gas.
* Sometimes, when I press the gas pedal, it will stick.
* It backfires at higher rpms when I'm cruising.
* The ECS light is on.
I've replaced the spark plug wires and both the main and secondary fuel filters.
What should I check next?
My .02
You can adjust your idle speed at the carb, I don't know what you have done to your car prior, but it sounds like you have something wrong with your accelerator cable or your carb. I would determine why your gas pedal is sticking and go from there.
On my 84 DL the ECS light is always on now that I put a hitachi carb on and removed all the vac lines.  A tiny bit of black tape fixed that :)
Your backfire issues "could" be your timing out of adjustment, spark plugs, or plug wires not playing nice.
I guess it is important to consider what you have done to the car prior to this and see if any of those things could have resulted in a negative effect.
Is the idle sloppy as well?
"* My car idles really low, and it will die unless I give it gas."
Idle adjustment, vacuum leak/s, retarded timing.... As stated, and are easy places to start. Also could be due to your ecs failure.
"* Sometimes, when I press the gas pedal, it will stick. "
Potentially unsafe condition. Check for frays and wear in the cable where it exits the cable sheathing behind the carb and gas pedal. Often they are at a bad angle near the carb and the cable is worn into the exit point.
"* It backfires at higher rpms when I'm cruising."
Float setting, egr issue, timing, vac leaks or the highspeed solenoid is outa wack.
"* The ECS light is on."
Been so long since ive messed with the feedback crap, but i do remeber if the system is intact when in fault mode it goes full rich.
Ill look for the code reading link. Its a little more involved than the spfi ea82s. Honestly trying to salvage a feedback system unless you have no choice is far too much trouble. Trust me ive tried.
Do you have 2 feedback solenoids?
Edited by ihscout54
