neebski Posted March 12, 2015 Share Posted March 12, 2015 Hey guys, a buddy of mine needs to get his truck out of West Virginia after it broke down on our last snowboarding trip. My question is, can my 08 Limited, with the towing package handle towing his 07 Toyota Tundra? We are considering using a dolly where his rear wheels are on pavement and front two on the dolly. His truck is approximately 5000 lbs give or take a few hundred. Has anyone had any experience with this?Don't want to stress the vehicle too much going over some mountain passes and a 300 mile trip back to eastern Virginia.Any help would be great! Thanks! Link to comment Share on other sites More sharing options...
ccrinc Posted March 12, 2015 Share Posted March 12, 2015 Towing specs: Tow 3,500 pounds with transmission cooler.2000 pounds without transmission cooler. Tongue weight: 200 pounds, 300pounds with transmission coolerTrailer brakes are required when the trailerand its cargo exceed 1,000 lbs. Link to comment Share on other sites More sharing options...
neebski Posted March 12, 2015 Author Share Posted March 12, 2015 In short, No. That's the consensus I've got at least. Thanks! Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 12, 2015 Share Posted March 12, 2015 (edited) Tribeca is about 800 pounds lighter than the towed vehicle. Plus the weight of a dolly and you'd be working it pretty hard. Can the tribeca do it? Physically, yes. However, that truck will be trying to shove the subaru around on any curves and downhill grades unless you get a trailer with brakes - which equals more weight. Safety and the potential for wear/damage to the tow vehicle say it would be a bad idea. On a short trip with flat ground I'd say take it slow and go for it. For 300 miles and mountains, best to rent or borrow something big that's more apt to tow that sort of load. No sense risking life, limb and subaru to save a few $$$. Hertz, Penske and a few other rental chains will rent vans and trucks with tow packages by the day. Edited March 12, 2015 by AdventureSubaru Link to comment Share on other sites More sharing options...
Rooster2 Posted March 12, 2015 Share Posted March 12, 2015 I too, don't advise towing a large truck with a Tribeca. It was never made to haul something that big and heavy. A good rule of thumb, is to always tow using a larger vehicle to pull a smaller vehicle or trailer, never the other way around. I have consistently got a better hauling rate from Budget Rent a Truck vs Hertz, Penske, or U-Haul. Suggest you get quotes on line for cost per mile, and drop off fees if ever considering renting a truck, trailer or dolly. Seems like all the truck rental vendors have "deals" going on all the time. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 12, 2015 Share Posted March 12, 2015 Consider renting a truck and trailer to do the tow. West Va is pretty hilly and the Tribeca will have a hard time with that terrain. No sense risking tearing up your own car to save $200. You should also check with local towing companies to go get it. Sometimes you can work out a deal for a lower rate on long tow when it's not a critical "need it done right now because I'm stuck on the side of the road" sort of thing. 1 Link to comment Share on other sites More sharing options...
Ibreakstuff Posted March 12, 2015 Share Posted March 12, 2015 A uhaul pickup is really cheap, if more than 100 miles it comes out to about 50-60 cents a mile. Transport is 50 bucks a day and comes with trailer brakes. 1 Link to comment Share on other sites More sharing options...
idosubaru Posted March 13, 2015 Share Posted March 13, 2015 yes, you could do it, drive slow and carefully.. particularly being winter time/lower temps. mountains would suck - if you're going I68 through Maryland that would be an awful drive. i don't recommend that - better off just towing it with a dedicated trailer. Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 13, 2015 Share Posted March 13, 2015 Without trailer brakes, it's a really bad idea. The potential for a bad wreck, and the massive medical bills that come with it far outweigh the savings of using your car vs renting the right equipment to do the job. 1 Link to comment Share on other sites More sharing options...
ccrinc Posted March 13, 2015 Share Posted March 13, 2015 What ^^he^^ said. Link to comment Share on other sites More sharing options...
