http://www.ebay.com/itm/11-12-LEGACY-PASSENGER-SIDE-VIEW-MIRROR-POWER-HEATED-W-O-TURN-SIGNALS-163897-/351252410585?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2012|Make%3ASubaru|Model%3AOutback&hash=item51c84670d9&vxp=mtr
Looks like it's still about the same process. Pop the plastic cover on the inside. usually a few 10mm bolts to remove the mirror after the cover s off. Disconnect the wiring harness and then install the new one in reverse order.
Ebay seems to have a few aftermarket ones as well as original used. If yours is painted to match the car it's worth hunting for a matching color via ebay and car-part.com.
If not a body shop can match and paint it. Or you can get a spray can made in the same paint color as your car from automotive paint supply stores and paint to match.
Edited by AdventureSubaru
