falconer315 Posted March 19, 2015 Share Posted March 19, 2015 I just bought an '05 Baja and I haven't had a chance to go through it yet with a fine tooth comb to make sure all the fluids are at proper levels. (That's this Saturday.) When I first took it for the test drive it didn't have noise, but when I picked it up from the dealer it was there is now a whining in the back of the car when slowing down. The dealer said only thing he had done was new tires and new brake pads all around to pass inspection. The noise gets louder when I put on the brakes, but the pitch doesn't change. It sounds almost like a turbine engine powering down, not like brake grinding or road noise. I've heard that whenever the tires are replaced an alignment needs to be done to prevent damage to the rear diff, could this possibly be the source of the noise? I haven't tried putting in the fuse to turn off the AWD, but that'll be my next test if need be. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 19, 2015 Share Posted March 19, 2015 Did they replace the tires AFTER your initial test drive? If yes, I would suspect the tires. What brand and model are the new tires? You can search for reviews of them on google or one of the many tire sites and see if other people complain of noise associated with that tire. Alignment has no affect on differentials. Mismatched tire sizes will have an affect on the differential, but any damage done typically takes thousands of miles unless there is a huge difference in size. Link to comment Share on other sites More sharing options...
falconer315 Posted March 19, 2015 Author Share Posted March 19, 2015 Yes, the tires were replaced after the initial test drive. I'll look them up to check reviews re: road noise. But wouldn't that also occur in the front of the car as well? I'm only hearing this in the back end of the car. The other reason I'm not suspecting the tires is because it occurs on both the asphalt road as well as my gravel driveway. (Very low pitch when in reverse, but still evident.) Thank you for confirmation regarding the alignment, that takes a lot off my mind. Still have to check the fluid levels this weekend though. Link to comment Share on other sites More sharing options...
brus brother Posted March 20, 2015 Share Posted March 20, 2015 If you suspect something wrong with the rear tires, swap tires front to rear and see if the noise travels with them. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 20, 2015 Share Posted March 20, 2015 um, they replaced all 4 tires right? Link to comment Share on other sites More sharing options...
falconer315 Posted March 20, 2015 Author Share Posted March 20, 2015 Yes, all 4 tires replaced with new. All same brand, model & size. I'm having an alignment done tonight on the car, i'll ask them to rotate the tires front to back and see if that helps. I'm also going to check the rear diff fluid levels while they've got it on the lift. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 20, 2015 Share Posted March 20, 2015 if there's any indication the car was driven thru very high water - just have the diff fluid replaced. Or do it anyway, when was it swapped last? it's def not common, but possible for a diff's vent to suck in water if fording high water. Link to comment Share on other sites More sharing options...
falconer315 Posted March 20, 2015 Author Share Posted March 20, 2015 No idea when the last routine maintenance on this car was done. All I know is that the engine looks clean and is virtually rust-free. Unfortunately it didn't come with any maintenance records, so I'm guessing at everything. Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted March 21, 2015 Share Posted March 21, 2015 Is there any sort of growling/whine/rumble when taking off quickly (Like pull auto into "1" or 1st gear and give it hell)? Does the noise change when taking left or right turns? Link to comment Share on other sites More sharing options...
falconer315 Posted March 23, 2015 Author Share Posted March 23, 2015 I'll have to try that and let you know. I had an alignment done this weekend, it needed one anyway, but no change after. The shop was closing and didn't have time to rotate the tires front to back, but they did suggest that it could be the new brake pads settling into the old rotors that were left on when the dealer had the brakes changed. Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted March 23, 2015 Share Posted March 23, 2015 (edited) Figures the dealer would just pad slap... A possibility, especially with grooved/unsurfaced rotors. EDIT: OR the dealer went to town on the rear hubs/rotors to get them off and has damaged a wheel bearing. The hard left/right test doesn't work quite well with rear bearings. Edited March 23, 2015 by 86 Wonder Wedge Link to comment Share on other sites More sharing options...
