Singularity21 Posted March 19, 2015 Share Posted March 19, 2015 In the 2.75 years I've had my 1978 GL, I've had the great privilege of replacing the clutch cable 7 times. It's broken in a variety of places and I've been able to figure out only a couple of the reasons as to why it broke there. The one that plagues me the most is what's pictured, where the housing support ring shears off and no longer retains the housing causing a lack of enough tension to apply the clutch. I don't know if this is a crummy part from O'Reiley and that's why it has a one year warranty or if I'm installing it incorrectly, because I'm not entirely sure what the rubber flap with the bolt is for and never attach it. Thanks for your time. Link to comment Share on other sites More sharing options...
moosens Posted March 20, 2015 Share Posted March 20, 2015 That sling , many of which are leather , has a spring that hooks from it to a small sheet metal piece atop the transmission. The mid point assistance makes a huge difference in tension. I've tried to use a leather shoelace in place of the spring but instead ran it up to a spot I could tie off to but that was not good enough. The rubber piece with the washer is the grommet for the firewall and you want to tuck that washer into the rubber - you'll see when you get up close to it. Yes , these are a pain. Check the pedal box for breaks in the side wall caused from excessive pressure we all tend to apply in hopes of shifting near normal. 1 Link to comment Share on other sites More sharing options...
bertmann73 Posted March 31, 2015 Share Posted March 31, 2015 i finally gave up on buying cables and made my own from old stuff in the garage. it snaps every 6 months or so and i go another inch until i dont have any cable left. then i find another 1 Link to comment Share on other sites More sharing options...
Singularity21 Posted March 31, 2015 Author Share Posted March 31, 2015 Thanks for the heads up about the spring attaching to the transmission Moosens. Whoever replaced the clutch before about the car had that spring somewhere else. Now that I've moved it to the proper location it feels brand-new. 1 Link to comment Share on other sites More sharing options...
moosens Posted April 1, 2015 Share Posted April 1, 2015 Right on !! Link to comment Share on other sites More sharing options...
