nicholi2789 Posted March 20, 2015 Share Posted March 20, 2015 Hey guys, looking to get some bigger rims and tires for my 95 subaru. I'm looking at a set of 17s. I was curious what is the biggest size I can fit without rubbing a ton and modifying the suspension. Anybody put on a set of 17s with the stock suspension? The wheel size for the ones I'm looking at are:P215/55 R 17 buying them used for a good deal that's why the odd size. Thanks. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 21, 2015 Share Posted March 21, 2015 Depending on the wheel offset, that tire size is likely too large and the tires will hit the rear strut spring perches. Overall diameter of that tire size is slightly larger than stock Outback tires. Outback tires drag on non-outback struts. 1 Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 21, 2015 Share Posted March 21, 2015 A good place for checking tire and wheel sizes is www.willtheyfit.com 1 Link to comment Share on other sites More sharing options...
ocei77 Posted March 21, 2015 Share Posted March 21, 2015 Another great visual site is shown as an attachment. O. rimsntires.txtFetching info... Link to comment Share on other sites More sharing options...
nicholi2789 Posted March 21, 2015 Author Share Posted March 21, 2015 Thanks guys. Appreciate the responses. So it tells me they will fit basically but not how close it's gonna be. My speedo will be off a few mph and I can deal with that. I just wanna know how bad they will run. A little rub is okay by me until I can get Outback suspension and stiffer sway bars. I was curious what the biggest rim size is that people have used and got away with on stock suspension. Link to comment Share on other sites More sharing options...
ocei77 Posted March 21, 2015 Share Posted March 21, 2015 the rimsntires site does. I have 17" Enkeis with a 52 offset on my 96 OB. O. Link to comment Share on other sites More sharing options...
nicholi2789 Posted March 21, 2015 Author Share Posted March 21, 2015 On 3/21/2015 at 12:01 PM, ocei77 said: the rimsntires site does. I have 17" Enkeis with a 52 offset on my 96 OB. O. And how bad do they rub? The outback has a little more clearance too tho. Link to comment Share on other sites More sharing options...
ocei77 Posted March 21, 2015 Share Posted March 21, 2015 They do not rub, Use the site I mentioned. You will not have a problem with the sedan. The width of the tire is the major issue. Cannot go wider than 225/45 on a 17" rim ( which is what I have). Which is the same tire and wheel combo I used on an 07 Legacy. The strut mount location is what gives the clearance. The centerline from the hub to fender distance is the same. O. Link to comment Share on other sites More sharing options...
nicholi2789 Posted March 21, 2015 Author Share Posted March 21, 2015 On 3/21/2015 at 4:39 PM, ocei77 said: They do not rub, Use the site I mentioned. You will not have a problem with the sedan. The width of the tire is the major issue. Cannot go wider than 225/45 on a 17" rim ( which is what I have). Which is the same tire and wheel combo I used on an 07 Legacy. The strut mount location is what gives the clearance. The centerline from the hub to fender distance is the same. O. Ah okay. So the wheels I was looking at are too big then.they are 55. That sucks they were a super good deal. Ooh well, I'll just look around for some wrx rims or something. Link to comment Share on other sites More sharing options...
Aluxes Posted March 22, 2015 Share Posted March 22, 2015 What about going with adjustable coilovers? Then you should have no problem running those tires. This is the set-up I'm putting on my 97obs. It works out to be around the same price wise, and easier than using the legacy struts Link to comment Share on other sites More sharing options...
