subaru forever Posted March 29, 2015 Share Posted March 29, 2015 Would a light switch from a 91 fwd sedan work on a 97 awd 2,2 sedan.the switch in the steering colum Link to comment Share on other sites More sharing options...
gbhrps Posted March 30, 2015 Share Posted March 30, 2015 subaru forever, Generally, you can swap parts like this across the same generation vehicle. What you're trying to do stretches two. That's not to say it wouldn't fit, but I wouldn't bet on it. Then again, compare the two of them closely. You'd be better off trying to get one from a wrecking yard from a 96 to a 99. Link to comment Share on other sites More sharing options...
subaru forever Posted March 30, 2015 Author Share Posted March 30, 2015 My switch is bad in my 97 sedan Link to comment Share on other sites More sharing options...
nipper Posted March 30, 2015 Share Posted March 30, 2015 If they look the same it should. Link to comment Share on other sites More sharing options...
Gloyale Posted March 30, 2015 Share Posted March 30, 2015 No will not work. You need a matching one from a sedan. If your car is has variable intermittent wipers, you need a switch that has the variable function. Would only have that if it's an Ls or Gt. Regular base or L model will just be one speed intermittent. 1 Link to comment Share on other sites More sharing options...
nipper Posted March 30, 2015 Share Posted March 30, 2015 SHoot thats right, unless you want to get into the nitty gritty of switches. What makes you think the switch is bad? Link to comment Share on other sites More sharing options...
