97 OBS rough idle
Thompjw628
I bought a 97 obs with 5spd swap...the swapper didn't mess with the ecu...so here's the issue while driving and Comin to a stop I usually downshift and compression brake bringin the Rpms up and when I get to a complete stop the car starts to idle rough and feels like it's missing if I turn it completely off and start it back up it will run fine again...been driving it like an auto the last couple days(while coming to a stop I just push the clutch in and use the brake only instead of compression braking) and I haven't had any issues...it is throwing a couple codes
  • 2 weeks later...
P1507 is the Idle Air Control Valve and could easily be the culprit of your problem.
I've never done a Subie swap, but on others (like Honda's) you have to swap the ECU from an MT or always have a check engine light.  I'm not sure if a Subaru is the same, but it's something to check out.
  • 1 year later...
I too am having this same issue with an EJ22 that I swapped into a vw bus.  Do you recommend changing out the IAC valve or adjusting it?  Or is this just something to live with?  There must be a way to get the ecu to recognize it as a manual transmission.
