ej22 harness difference
Hey all. I did try searching i just didnt find anything. I'm in the middle of swapping in a ej22 into my gl. The harness is from a 92 and the engine is a 90. The engine harness has three grey plugs while my harness has two white / grey plugs. Can I just switch the engine harness? Thanks
The third plug is almost all grounds on the early harness if that helps
it's all grounds. But the wires int the other 2 connectors have a completely f
Different arrangement. 1 wire of 1 of them is in the same spot
Get a correct intake harness
