Fram High Milage oil filter
The first video you posted MR Loyale is admittedly disappointing. That hole in the filter is unacceptable and is obviously a manufacturing defect.
The second video you posted was less of a disappointment to FRAM. Why? You may ask.
Because now days, all FRAM oil filters are manufactured with either cellulose or other synthetic media. Which means they are right on par with a most other companies. Now to address what you considered a sin above all others: CARDBOARD END CAPS :o  :o  :eek:  :eek:
Okay, okay, i'll quit the drama. Seriously though, the cardboard is not as bad as you would think. After All what is cardboard? Paper. What is one of the most common filtering medias used by oil filters? Paper.
Yeah I admit, the filter would definitely not win the contest for "toughest end-caps", but I doubt the endcaps are going to cause catastrophic engine failure due to poor filtration.
Also disappointing is that in the last video link you posted, was that the only reason that guy did that video was to make WIX look good. Plus, he was comparing a top of the line WIX filter with a filter-on-a-budget FRAM (aka frams most inexpensive option). In my opinion, to make it fair for the fram, he should have used one of frams premium ULTRA filters.
Here is a letter from fram regarding their use of cardboard end caps:
 Mr. Lawrence:
Thank you for the e-mail regarding the construction and micron rating of Fram oil filters. We welcome
the opportunity to be of service.
Fram filters meet the requirements of the original equipment filter designed for a specific engine. Our
filter applications follow the recommendations of the vehicle manufacturer for form, fit, and function.
Fram filters follow internally targeted design guidelines to meet the functional requirements of a given
filter. Fram filters are tested against SAE standards to ensure uniform product quality and performance.
Material construction will vary between filter manufacturers. We believe Fram filters have a proven
record for providing reliability, superior quality, and engine protection over the service life of the filter.
A common misunderstanding among our customers concerns the end disks in the oil filter. These disks
hold the glue which keeps the pleated media formed into a rigid circular tube. The glue-to-media
interface is also one of the sealing surfaces keeping dirty and filtered oil from mixing. One common
myth is that only metal end disks can adequately seal and have enough strength in the hot oil
environment. For this reason, Fram filters are criticized for having cardboard end disks. The issue is, the
material doing the sealing is the adhesive, regardless of the material of the end disk. What matters is the
strength of the adhesive, its proper curing, the thoroughness with which it can be applied to the disk,
and its adhesion to the disk. By using cardboard end disks, Fram filter engineers are able to specify
adhesives with excellent strength and sealing properties, and strong adhesion to the disk (intuitively, it
is easy to make a strong glue bond with cardboard). Moreover, just as paper media itself is able to
withstand the hot oil environment, so too is the end disk designed of fibers engineered to be strong and
nert in hot oil. The thickness and strength of the adhesive also stiffens the end disk considerably.
Fram engineers perform hot oil circulation tests on the filter element and also regularly cut open used
filters to examine how well they have withstood the rigors of actual use on a vehicle. For over 38 years,
Fram end disks have stood up to hot oil and their adhesives have sealed off the dirty oil.
Fram's latest entry in the automotive oil filter market is the X2 Extended Guard oil filter. The Fram X2
Extended Guard filter uses a filter media that includes a reinforced mesh screen for maximum pleat
integrity, durability, and oil flow. The inclusion of the metal screen increased the glue tolerances or
thickness required for proper adhesion to the end disk. The original X2 prototype development specified
the cardboard end disk technology. However, the increased amount of adhesive required to join the
cardboard end disk to the screened media resulted in prototypes that did not conform to design
standards. We had no choice but to use a steel end disk with the X2 filter media to provide uniform
Extended Guard oil filter construction.
Fram automotive oil filters, including the standard Extra Guard and premium X2 Extended Guard
filters, have a micron rating of 10 micron.
If you require further assistance with Fram filter construction, please contact the Fram Engineering
Department directly at 1-419-661-6700.
Thank you for your interest in Fram filters.
Cordially, Scott Jacobs, Catalog/Technical Service Representative
Feel free to let loose with the hail of insidious comments directed at FRAM and at my use of their filters. Fire when ready Gridly!  :popcorn:  :popcorn:
Well Sapper thank you for the response. Just for the record,  I personally could care less what oil filter you use nor what toilet paper either. And if by some coincidence you can make an economy of scale combining the two I applaud you sir!
First off, cellulose is NOT a synthetic media and so is not on par with other media like fiberglass mesh. Why?
Also as explained in the WIX comparison video, the spaces between the strands in cellulose are nonuniform in width which means the filtering ability will have great variation.  Some areas will have strands close together, restricting flow while others far apart letting contaminants through.  Here is a microscopic close up:
Most cheapo oil filters use paper.  Toilet wipe is also made of paper. Coincidence?
 Mr. Lawrence:
the opportunity to be of service. .....
Did you PERSONALLY write "Mr Lawrence" or just copy and paste it from a FRAM fanboy website?  Please cite the source for context if you did not personally write to FRAM.
I will give him credit for admitting the end-caps were cardboard. In the past they have danced around the term to mislead the public giving the end-cap material various euphemisms so as to avoid acknowledging it is really cardboard.  .
It is also interesting the lengths to which FRAM goes to convince the consumer that the cardboard end-caps are just as good as metal end-caps and their sheet paper (cellulose) filter media is just as good as fiber mesh reinforced material yet their more expensive (xtra guard etc) include steel end-caps and mesh reinforcement. You don't need a PhD in logic to see the original premise that is flawed. In short, if a paper end-cap and paper filter material were "on par" with steel end cap and mesh reinforced fiberglass, there simply would be no need for an "extra guard" or "x3" type FRAM filter as the originals would be be as good or better.
What is insidious is the FRAM marketing hype that tries to push off a filter made of an inferior material as being on par with a quality constructed filter.  Cheaper supply chain materials costs means larger corporate profits for FRAM and the retailer, not better filtration for the end user. And since the likelihood of any of their prospective customers having the financial means to prove an engine failure was caused by their products let alone pursue it in a court of law ($$$$), they are probably safe in their market space.
Your use of FRAM is your business. All we can do is offer our opinion and experiences. However If you ever post a TOD thread at some future date asking for help, don't be surprised if your use of FRAM filters is called out as a contributing factor.
But you will still be warmly welcomed at the next WCSS!
Edited by MR_Loyale
Hmmm... I do love a good spot of logic, Watson ol boy.
Here is your source: http://www.gwrra-ohh2.org/pdf/oilfilter.pdf the letter is at the bottom of the pdf. As a matter of fact, it was not a "fanboy" website, but rather a review a guy did on a bunch of different oil filters. He was another FRAM hater, although for good reason, this was before fram discontinued their piece-of-crab economy series.
"It is also interesting the lengths to which FRAM goes to convince the consumer that the cardboard end-caps are just as good as metal end-caps and their sheet paper (cellulose) filter media is just as good as fiber mesh reinforced material yet their more expensive (xtra guard etc) include steel end-caps and mesh reinforcement. You don't need a PhD in logic to see the original premise that is flawed. In short, if a paper end-cap and paper filter material were "on par" with steel end cap and mesh reinforced fiberglass, there simply would be no need for an "extra guard" or "x3" type FRAM filter as the originals would be be as good or better."
Just to clear up some confusion, he ULTRA (sometimes called the Xtended Guard) in other words, the Xtended guard and theExtra guard are two different filters is the mesh reinforced filter.
The grave problem we have here is that your experiences and opinions (or perhaps those of your friends/family as well) are clashing with my experiences and opinions(and my familys and friends). Your opinion, if I am reading this correctly, is that FRAM is the devil and that all their factories should be burnt to the\ ground, their executives drug out and shot, and their employees lynched. This is of course a very, very, extreme example and more than likely is not your actual opinion. More than likely, all you really want is their production standards raised. BUT...Well... to be honest I like using extreme examples :D:P
My opinion is that FRAM is to be revered and all their filters are made of pure gold and are hand knit by angels. Again, a very extreme example and an unrealistic one. I recognize that FRAM has had issues with QC, but I think they are past that stage.
Our opinions clash; neither one of us is willing to yield our positions based on experiences, research ect. As long as they work, which thus far they have for my whole family for 25+ years, I have no problem with FRAM.
And dont worry, if/when I come crying to USMB about TOD, you'll be the first to know.
Edited by Sapper 157
Well Sapper thank you for the response. Just for the record, I personally could care less what oil filter you use nor what toilet paper either. And if by some coincidence you can make an economy of scale combining the two I applaud you sir! !
lol that made me laugh pretty hard, haven't laughed like that in a while.. Edited by Subasaurus
Thanks for posting the source of that letter and the link.  The pdf begins  :
"Oil Filters come basically in three qualities. Very good, with excellent filtration; normal; and really
incredibly bad. This last category, really incredibly bad, should obviously be avoided. Accordingly, never
use a Fram, Pennzoil, Penske, Castrol, or Quaker State oil filter in any motor you like. All of these filters
are made by Fram.
For the record I don't think FRAM is the devil nor should their factory be burned to the ground and their employees are probably just trying to feed their families. The jury is still out on their executives however.
FRAM is the choice of Cheap Bastards (CB) everywhere. Now don't get me wrong, I am a cheap bastard at heart. Father time however has brought me to a new level of Cheap Bastard Enlightenment (CBE).  Because in every action you do there is a reaction.
If I choose to drink CB beer or wine (two buck Chuck) and save some bucks, I might find I get a reaction of gaseous rumblings and liquid poo the next day.  If I choose the CB bread I might save some bucks and but I won't get nutrition I need and maybe later I will fall ill with cancer due to the chemical fillers they use.  By the time you reach my age, you have either learned something from those experiences or you just do the same thing over until you die. If you learn from the previous experiences your CBE level goes up.
If I use CB filters on my beloved Subaru, the thing that gives me freedom, I might get a reaction such that the Subaru doesn't move any more and I will have lost my freedom.  But that is where I draw the line my friend. They can take away my beer, my bread my toilet paper...
If your Subaru is still running this July-August I hope you make it to WCSS.
Edited by MR_Loyale
  • Like 2
Well the good thing is if I run out of toilet paper I can always reach for the Fram filter the pleated paper should make for a thorough wipe.
yes, if your ever in the forest and you really need to go, you remove your oil filter, take it apart and use that, or just keep a bunch of fram filters in the tool compartment in the back and some sheet metal cutters and your set for your trip.
Loyale,
I am the tech manager at FRAM. If you give me the year and model and (engine size is 1.8) I can send you the correct filter part number. As for those in here bashing FRAM, are you aware that FRAM manufactures Subaru OE filters for Subaru?
Thank you but I found the correct filter using the Fram website. I was not aware that Fram is the OE for Subaru. I have used fram filters everytime I do my own oil change. My thoughts are that it is a disposable part so why spend the extra money.
Hey Sapper you make a valid argument with the evidence you have provided :P
EDIT:
Annnnnndddd there is a second page of comments that I just saw lol.
MR_Loyale very excellent rebuttal. You and Sapper are too funny I am enjoying the banter.
Edited by loyale1993
Here's a good one I found while researching this topic...http://www.austincc.edu/wkibbe/oilfilterstudy.htm
Like I said, FRAM has had some issues, but that study was done years ago and I believe that since this study has taken place, FRAM manufacturing standards have improved immensely. This was also before they introduced xtended guard, which does have metal endcaps, a silicone bypass valve, dual layered synthetic media, and a wire mesh reinforcement. I still find it hard to believe that FRAM was as bad as people say they were even back then though, because my dad ran (and still runs) FRAM extra guard on our family's vehicles... NEVER had an issue.
  • 5 months later...
I have one bad experience with a fram filter which will steer me away from them forever.  On the first oil change of my 'new to me' 360 magnum in my dodge truck i removed the fram filter that the previous owner had put on and found out there was NO oil in it.  Now this motor does not have an oiling problem and runs great with good oil pressure but the frams from what i read do not have an anti-drainback valve and all the moving of the motor from one truck to the other caused all the oil to return to the pan.  I would personally like oil in the filter on first startup.
Edited by hatchsub
